Results 1 to 10 of 10
Thread: Noob, chemical and skimmer questions
    Jun 2013
    SW OKC
    29
    Been reading for about a week and got a few questions:
    1. Can you install a thru the wall skimmer and hook it up to the factory pump/filter, or do you have to run it to a sand filter?
    2. I tested using a 6-way test kit from WalMart (I know, get a good one. lol) and here are the results. I'd like to use the BBB method, so what do I need?
    CL/BR= 1/2
    PH= 6.8-7.2
    ALK= 40
    Hard= 60
    CYA= -30
    18x48 Intex Ultra Frame, 6,423gal, 1500gph Cartridge, SWG, Setup June 2013.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Noob, chemical and skimmer questions
    First off your chlorine is low pool-school/chlorine_cya_chart_shock , otherwise not too bad, pH needs to come up a bit.
    Ike
    p.s. normally we would say you need to raise your CYA some, but I would say not to do that until you get a chlorine test that can read above 5 ppm
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Check this chart out. Chlorine/CYA
    You need to add enough bleach to bring your chlorine to 4 or 5, near the top of the range of your tester. Your pH is a bit low, could come up a tiny bit. Borax will do this. Use the Pool calculator to figure how much. Add half what the calculator suggests, then test again in an hour. If it still needs more, do the half dose again. Sneak up on the target.
    There are several threads here like this one skimmer above the weld, many have already added a through wall and posted how they did it.
    Jun 2013
    Hartland, MI
    67
    I think those cheap kits only test tc so you'll never know how much is fc and how much is cc. You could run into problems if you don't know your cc level. Looks like you might need to raise your ta/alk and your ph.
    24'x54'' AG
    Appox. 13800 gallons
    150lb Hayward sand filter
    1.5hp pump
    Well water
    Jun 2013
    Fallsburg, NY
    258
    Yes, the ultra frames can handle the hayward skimmer with no problem. The skimmer relies more on gravity than suction. You may not be able to use a vacuum with the skimmer if you have a weak pump, but the skimmer will work as long as the water level is above the bottom lip. The only Intex pump/filter that is practical to run the vacuum through is the 2650 ghp sand filter (or the 4000 if you can find it). I've heard of some people that may have gotten some vacuums to work with the 1600 sand filter, but I can't confirm.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Vacuuming works just fine with the pump I have.
    Jun 2013
    SW OKC
    29
    Is there a common skimmer everyone is using? I see alot of different ones on Amazon.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    hayward spx1091 seems to be the popular one.
    Casey's Avatar
    SW PA
    10,446
    OT... (sorry) Is that a rotty? They are great dogs as I own a rottweiler too! The nubbins is giving it away!
    Jun 2013
    SW OKC
    29
    Thanks for the advise, I'm gonna take it and hope for the best.
    He is a Rotterman, Rottweiler/Doberman mix. Bought as a full blood Rott with no papers from craigslist, turned out after watching him grow and alot of research, he's a Rotterman. And he's a great dog all around, he's mostly spoiled to the indoors but when he gets outside he runs like a race horse (as you can see there is no grass along the fence) and he eats a ton. He only weights about 70lbs. I'll see if I have a better pic of him from my home computer later.
