Thread: Aluminum
    Aug 2011
    Houston Texas
    17
    Aluminum
    Chemically speaking, should all things aluminum be kept out of the pool for the sake of the water (avoiding contamination)? Or is it simply the aluminum that may be negatively impacted?
    Circa 2000 - IG 20k Gallon Plaster/Gunite Pool - Painted (though much of the paint has worn back down to the plaster)
    FNS Plus DE Filter (60 sq ft?) - Formerly paired with 3/4 hp Pentair Challenger pump
    Re: Aluminum
    Aluminum works fairly well with swimming pools in the short run. Longer term it tends to suffer corrosion. Things that are not left in the water are fine. For example aluminum poles for pool brushes work well. But aluminum pool ladders can have problems over the longer term. If you do have something aluminum in constant contact with the water you want to use a sacrificial anode connected to the bonding system.
