Results 1 to 10 of 10
Thread: High FC
    Jul 2011
    Webster,Wi
    62
    High FC
    I did a test tonight and I'm a little concerned with the FC.
    FC: 15
    CC: .5
    TC: 15.5
    pH: 7.2
    T/A: 120
    CH: 100
    CYA: 60
    I need to raise the cya alittle and the ph but what about the FC?
    18'x52" Intex round AGP, 2650 Krystal Clear SWG pump with sand filter and a Hayward H100ID pool heater. TF100 test kit to keep the water sparkly clean.
    30,432
    Re: High FC
    Leave everything alone except dial back your SWG or turn it off until your FC reaches about 5 ppm then restart SWG on a lower setting.
    Your pH will come up on it's own and you can add about 10-20 ppm CYA whenever you wish....no hurry.
    Jun 2013
    Hartland, MI
    67
    Re: High FC
    I'd watch your ph, if your fc is that high and your ph is 7.2(not sure the accuracy with the high fc) from what I've read a lot of chlorine should raise your ph so keep an eye on that.
    24'x54'' AG
    Appox. 13800 gallons
    150lb Hayward sand filter
    1.5hp pump
    Well water
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: High FC
    Quote Originally Posted by durandetto
    Sent from my SPH-L720 using Tapatalk 4 Beta
    Good catch!
    pH shouild be rechecked and adjusted after FC dips below 10.
    High FC doesn't actually change the pH, it changes the phenol red reagent so it misreads.
    Jul 2011
    Webster,Wi
    62
    Re: High FC
    I can turn the swg off for a while and when the FC drops I will adjust the pH. I have a jug of the pH Plus from Walmart, is that good to use?
    Richard320's Avatar
    Jan 2010
    19,067
    Re: High FC
    Quote Originally Posted by MK1985
    Yes. That is Soda Ash.
    Re: High FC
    With your TA at 120, your pH will rise on its own. Adding pH increaser would probably result in a too high pH. Just wait and retest. You could add an eyeball to the return to allow the return water to ripple the surface, which will help raise the pH.
    Support the site
    30,432
    Re: High FC
    +1 what JamesW said.
    Jul 2011
    Webster,Wi
    62
    Re: High FC
    Thanks for all the help and ideas I will see what I can do, also is it safe to swim because it's crystal clear and warming up slowly.
    30,432
    Re: High FC
    Swim away!
