Results 1 to 12 of 12
Thread: Adding Chemicals before a storm?
    Jun 2013
    Hartland, MI
    67
    My fc is at 1 and my ph is at 7.8. I was gonna turn my filter on and add some bleach, but I didn't know if it was a good idea to do this before a storm.
    24'x54'' AG
    Appox. 13800 gallons
    150lb Hayward sand filter
    1.5hp pump
    Well water
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Adding Chemicals before a storm?
    Yes, you don't want your FC getting low in a storm particularly if there is a chance debris will get into the pool
    Jun 2013
    Hartland, MI
    67
    So, it won't hurt to run the filter overnight during a storm?
    24'x54'' AG
    1.5hp pump
    Well water
    Jun 2013
    Hartland, MI
    67
    Also to not add another thread what do you recommend for a partially color blind person trying to read test results? The ph I don't have a problem with but the ta and fc ones are really hard for me to judge. I can see cheap test kit chlorine levels because they have a color comparison, but I'm afraid it's not that accurate. With the Taylor kit I have its hard to tell the change from pink to clear and basically any other color change test.
    24'x54'' AG
    1.5hp pump
    Well water
    30,424
    Storm coming or not, Your FC is already too low. The single biggest issue people have with their pools is not maintaining adequate chlorine. If you tell us your CYA level, we can tell you where your FC should be.....but it's gonna' be higher than 1 ppm.
    I have no advice for not being able to see a color change. Can someone help you?
    Jun 2013
    Hartland, MI
    67
    I will test my cya tomorrow because it will be a week since adding my first cya to my new pool. I've been trying to keep around 5 with a projected cya of 30-40. I've been fighting a high ta level, but I'm afraid to add too much ma at once and not sure when it's safe to swim afterwards. I really appreciate all the quick responses I get. I recommend this site to everyone I know with a pool or planing on getting a pool.
    24'x54'' AG
    1.5hp pump
    Well water
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The best suggestion I have is the TF-100, the only color matching test in it that you need to use is the pH test, all the others are drop counting and looking for a color change (clear / red or red/blue) (this excludes the color matching OTO chlorine test as you can use the FAS-DPD drop counting test in its place, it just takes a little longer to run, and reagent cost a little more)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    You only need to let the water circulate about half an hour after adding chemicals before adding the other. No need to run the pump overnight unless that's when you usually run it or you're in the middle of the shock process. And actually, if you add stuff in front of the return it disperses pretty fast and you swimming in it will actually aid in getting things mixed well. I wouldn't hesitate to jump in minutes after adding bleach or acid.
    30,424
    Don't worry about the TA until you better control your FC.
    Jun 2013
    Hartland, MI
    67
    Ok, thanks for the quick responses. I usually run the pump overnight and test after work then add chemicals accordingly.
    24'x54'' AG
    1.5hp pump
    Well water
    Jun 2013
    Hartland, MI
    67
    I usually keep my fc at a better level but I had softball tonight so I neglected it a little longer than usual. Plus I'm not sure my cya level yet because it hasn't been a week and I've had to back flush my filter a couple times due to the iron in my pool. I will test my cya tomorrow and adjust accordingly.
    24'x54'' AG
    1.5hp pump
    Well water
    Medic3's Avatar
    Jun 2011
    Missouri
    42
    I usually turn my pump off during any windy weather because my skimmer basket will fill up with leaves from nearby trees and, has in the past caused my pump to lose its prime.
    20,000 gal. 27' AGP
    Hayward 18" sand filter with 1 hp Hayward Matrix pump
    A convinced BBB user and TFP fan
