Results 1 to 7 of 7
Thread: Jandy Aquapure 1400 - what is this part?
    In the manual, it looks like its just the power cable. Should I just be able to swap it out or is what I'm seeing an indication of another problem?
    [attachment=0:2r2zk2rf]ImageUploadedByTapatalk1372208533.026898.jpg[/attachment:2r2zk2rf]
    Thanks for your advice!
    Lynn
    12000 Gallon Freeform Pool
    SWG
    Jandy AquaPure 1400
    Leslie's DPD Complete Chlorine Kit + FAS/DPD Chlorine Tester and Swirler from TFP.com
    Tree covered lot - cottonwoods and crepe myrtles. Great shade during the summer, miserable fall cleaning leaves from the pool.
    Jun 2011
    Long Beach, CA
    2,784
    Re: Jandy Aquapure 1400 - what is this part?
    That is the DC power cable, but what makes you think that it needs to be replaced?
    The green corrosion on it (maybe hard to see in the photo) and the 123 error that I'm getting on the Aquapure.
    SWG
    Jandy AquaPure 1400
    Jun 2011
    Long Beach, CA
    2,784
    Have you tried cleaning the cord and terminals? Make sure the power is off, clean the cord, cell terminals, and make sure inside the cell is clean. You might try to follow this troubleshooting manual, http://www.pleasurepoolsno.com/wp-conte ... Manual.pdf.
    I've pulled the DC cord to replace it and noticed that the corrosion ate through the center prong. Is my only option to replace the entire cell?
    Lynn
    SWG
    Jandy AquaPure 1400
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Yes.
    Okay, thanks.
    SWG
    Jandy AquaPure 1400
