Thread: safe, easy way to lower ph?
    Jun 2013
    Minneapolis, MN
    13
    I accidentally dumped in about three times as much borax as I was supposed to and now my pools ph is over 8.2! Is there any other way to lower ph? Will it go down over time? I don't have any muriatic acid and I really don't want to use anything that strong anyway.
    10' Intex Easy Set Pool with included filter, just over 1000 gallons. Fill water chlorine=1.5, fill water pH>8.2
    Aug 2010
    Dallas, TX
    4,052
    Re: safe, easy way to lower ph?
    Muriatic acid is the answer. It is used safely by people all the time, even me. What is your fear of it?
    In my experience, pH goes up over time, not down, even before I had a salt system.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Sorry, muriatic acid is the best, fastest, cheapest way to lower pH. Or dump the water and start over, since the pool isn't that big.
    Right now your pH is probably too high to be comfortable.
    Aug 2010
    Dallas, TX
    4,052
    How much borax did you put in? In my experience, it takes one gallon of MA to neutralize two boxes of borax.
    Butterfly's Avatar
    South Carolina
    10,045
    Use the PoolCalculator.com to help you figure the doses.
    The pool is small enough that you could dump some water, as Richard mentioned.
    You're done SLAMing when:
