Results 1 to 13 of 13
Thread: Help!
    Help!
    This is the first year I am using a saltwater system with my intex 18'x42" round pool. I purchased a 2500gph pump as well (yah maybe overkill but so be it). I have followed the charts and added appropriate salt and stabilizer. When testing my pool, these are the results:
    Copper: 0
    Free chlorine: low 0.5
    pH: ok 7.2
    alkalinity: high to very high
    I have tried the boost function for the copper part..didnt seem to help. My manual says I need to run it at 2 hours for its size but maybe I should run longer? Haven't tried yet. I vacuumed out the pool but the next day I always seem to have stuff back on the bottom. Don't know if its dirt, algae or what. It looks more brownish. I cannot "backwash" or whatever that is as I just have a simple pool setup. We have been getting alot of rain so I do I need to add an algaecide or is my saltwater system supposed to take care of all that? I think I read that I need to get my alkalinity lowered but I do not know how. Please help me, and be careful with all the chemical abbreviations and pool talk because I don't really know what they all are lol.
    Carrie
    Aug 2010
    Dallas, TX
    4,052
    Re: Help!
    Ignore copper. You do NOT want copper in your pool.
    You don't have enough figures here to properly maintain your pool. I don't see how much salt you have in the pool. Alkalinity needs to be a number. I strongly suggest you get your own test kit and take control yourself. Look on http://tftestkits.net for options.
    Pool school at the top right will help you with the abbreviations.
    You need to add bleach now to bring FC up to 3, then the SWG will take over.
    Re: Help!
    I thought you did want copper for the saltwater system.. it shows a range of 0.1 - 0.2 as the ok range. the alkalinity according to the test strip is 10. The salt I added was 95 lbs according to the chart for my size.
    Aug 2010
    Dallas, TX
    4,052
    Re: Help!
    Nope, no copper is necessary, and it's an undesirable in pools. It turns blonde hair green, which some people don't like.
    I don't think your TA is 10, if it is, it is way too low.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Help!
    That copper thing is Intex's answer to complaints of green pools. What the people who complain to the manufacturer are not telling them is that "I just put water in, and expect the SWCG to take care of everything".
    Here you will learn that copper is what turns hair and fingernails green, and can put some nasty stains on everything the water touches.
    By reading Pool School, you will learn that caring for your pool can be very simple, quick, and easy.
    Most people here that have the copper ion addition to the SWCG disconnect it as soon as they can.
    Test strips are notorious for being inaccurate, AT BEST. Do yourself and your pool a huge favor, and buy one of the recommended test kits. You will find in short order that this will be the absolute best investment towards keeping your pool clean, clear, and safe to swim in.
    Re: Help!
    I have read the pool school but its pretty much information overload for me. Too many combinations of chemicals and apparently I'm just not smart enough I will look into the test kits but if I spend any more money (that I don't have) on this pool, my bf will flip. I was hoping to SAVE money this year with the salt water. Thanks for your time
    Carrie
    Aug 2010
    Dallas, TX
    4,052
    Re: Help!
    The short of salt is:
    You want a CYA of around 70-80.
    I keep my FC around 4, you can go a little higher if you drift under 2 while the pump is off.
    pH will drift. Watch your pH, test at least every 3 days. If it's a huge problem, your TA may need to be adjusted.
    The largest problem is the pool stores don't test accurately in most cases, especially when it comes to CYA.
    Salt systems don't save money, it comes out about a break-even compared to using bleach. But it's way easier, especially for someone like me with a huge pool. I don't have to bring home hundreds of bleach bottles anymore. And, if you go on trips a lot like me, you can sleep easy knowing your pool is going to be chlorinated automatically.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Help!
    You are smart enough to seek the advice for great pool people here.
    Pool school can seem intimidating at first read, but as you read through it again some items will click.
    Don't get discouraged. We were all where you are now at one time.
    Re: Help!
    Charlie.. I am going by the only method of testing i have right now.. the test strips that came with my saltwater system. I posted the wrong number for alkalinity.. mine is according to the strip.. in between 180 and 240. Hard to tell because the color isnt exact. Either way its high compared to where its says is ok on the chart.
    Aug 2010
    Dallas, TX
    4,052
    Re: Help!
    Yes, that's going to be way high. Your goal is 70-80. With that high TA, I'm predicting huge pH swings, so you may want to test pretty often. You can work on getting that pH down as documented in Pool School.
    pool-school/lowering%20total%20alkalinity
    Re: Help!
    So I want to lower the pH even tho its fine? See why I'm confused... I have hth pH minus I got from walmart.. will that work?
    Aug 2010
    Dallas, TX
    4,052
    Re: Help!
    If you want, just see what happens with your pH after the SWG has been running a few days. You might get lucky.
    Re: Help!
    I've had it for a couple of weeks now lol. don't think its going to change. It runs for 2 hours a day. I have boost running on it now though
