Results 1 to 15 of 15
Thread: Speakers for travertine paver pool deck?
    Jun 2013
    Austin, TX
    70
    Hi, I have been reading on the forum for several months now - prior to and now as we are under construction on gunite pool in Austin, Texas. Due to being on steep lot, much of the pool is elevated above ground (all coping is between 1 to 4 feet above ground) and deck is level with pool - so no flower beds to put speakers in. Also, our deck is travertine pavers, set over a concrete base.
    I have a Sonos system to power 2 pairs of speakers around the pool and we are running conduit for wire under the deck to each speaker location. However, I have been pulling my hair out trying to figure out type of speakers and how to 'stub out' the termination of the conduit.
    There are two 'sitting areas' in the deck plan and one pair of speakers will go to each area. One will have rock privacy wall on two sides and the other has a 4' iron fence, basically in a semicircle around area. I prefer a 'clean' look and would love the look of the Bose round in ground domes, but the omni-directional speakers are a non-starter.
    My current 'best' idea is rock speakers on deck, the small Niles are fairly low profile and have good reviews. (http://www.crutchfield.com/p_190RS5PCW/ ... tml?tp=188)
    Option two is to get small wall mount speakers and to put on the wall in area one and on rail in area two, but I think my wall will be solid, so I would have vertical runs of wire from deck to speaker in all four locations. Also not sure how sturdy speakers would be on rails. Here are some Niles I have considered for this: http://www.crutchfield.com/p_190OS53W/N ... tml?tp=188
    For either option, I have no idea on how to stub out the termination in the deck and PB doesn't really have a suggestion, although he did say there is now a 4" pour-a-lid available, so I was thinking that with a hole drilled through might work. Particularly if I go with option one (rock speakers) I need some way to conceal and protect wire/connections.
    I have not found any good pictures or descriptions of either setup, so I would love to hear suggestions or experiences with similar setups! Thanks!
    ps: I have my TFT-100 kit and Stenner Pump/15 gal tank ready to go!
    12k gal IGP/Spa, gunite, Jandy 2HP ePump VSP, Jandy CL 460 Cartridge Filter, LXI400 Heater, PebbleSheen, Polaris 280, stenner 45MPHP10 auto chorine feeder
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Re: Speakers for travertine paver pool deck?
    I would say a weather proof electrical box. Then you could buy the hook ups for the box etc....
    BTW, I have the Stenner/15 gal set-up and it really is very nice!
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    Jul 2011
    NY
    51
    Quote Originally Posted by Telnet64
    Some pics would be helpful. If you're using outdoor rated direct burial cable there's no reason it needs to be in conduit other than for protection or through a chase.
    Omni speakers are inefficient, IMO you can do better. If you go with rock speakers you'll make the connection to the pigtail cable on the rock with silicone filled wire nuts.
    I have some pics of a recent install which may give you other ideas.
    But like I said, a few pics would be helpful.
    29,700 Gallon Vinyl Roman End, Sta-Rite Max-Therm-400HD gas heater, Sta-Rite S7M120 cartridge filter, Pool Pilot DIG-220 SWG
    Jun 2013
    Austin, TX
    70
    Thanks for the comments. I don't have pics as those areas aren't even formed yet (maybe this week, or definitely early next week). I'm using direct burial rated cables, but the wire will be under deck, so need conduit in case ever need to replace. I have seen the silicone filled connectors for outdoor use and plan on using them.
    With rock speakers in flower bed it's easy to conceal connectors and excess cable under them. Not so easy with travertine pavers, hence the idea for the 4" pour-a-lid.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    What are the joints between pavers going to be like?
    Could you have a paver that lifts out exposing a "trap door" at speaker location. You could drill holes through the pavers for wires and to lift it out of its spot.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2013
    Austin, TX
    70
    Harleysilo, that's an interesting idea and similar to what I was thinking of doing with the pour-a-lid. In Texas, the builders pour concrete and thin set the pavers to the concrete.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I've seen pour a lids before, with some carefully saw work you could cut a circle out of travertine, and thinset that in the pour-a-lid, assuming its not to thick.
    18'x43' Sport Pool
    Jun 2013
    Austin, TX
    70
    Yes, that's what my PB does. In my OP, I mentioned my current plan is rock speakers using these 4" lids with a hole drilled through for wires. Just making sure no better ideas available. It's amazing that I haven't been able to find anything even suggesting this after searching web and forums exhaustively.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Have you tried John Bridge tile forum yet?
    18'x43' Sport Pool
    Jun 2013
    Austin, TX
    70
    No, I haven't heard of that. Will check it out now! Thx!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    That's the go to forum for all things tile. Post up there and I'd ask about expansion joints on your patio, they are needed to prevent pop ups or tenting down the road.
    18'x43' Sport Pool
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Sorry to hit this old thread. Did you ever find your solution? Please consider sharing.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,191
    Quote Originally Posted by txnole View Post
    I think with today's technology I would be looking at Bluetooth speakers.
    Support the site
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Thank you. I was specifically interested in the OP's plan to run wire up/through his tile. Sonos and other products are, IMO, vastly superior to Bluetooth, not to mention the wide variety of options with outdoor speakers.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    I'm not arguing about hardwire should be better than Bluetooth but I got a couple of UE Booms and they're not too shabby
    http://www.cnet.com/products/logitech-ue-boom/
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
