Thread: PENTAIR MASTERTEMP HEATER CYCLING
    I have a Pentair Mastertemp 400 natural gas heater that keeps cycling on and off. It will heat the spa water up to about 97 degress then it will start cycling on and off every couple of minutes. I have the temp set to 104 degress but it will not reach that temp becuase it cycles. The HLS LED lights up on the back of the control board when it cycles off. I have tried replacing the high limit switch and the thermo regulator. Neither part fixed the problem. I have noticed the exhaust starts to get hotter before it cycles off. Does anybody have any suggestions on what to check next?
    ps0303's Avatar
    Jul 2011
    FL
    3,691
    Re: PENTAIR MASTERTEMP HEATER CYCLING
    So you do not have a control system with automation?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    I have the easy touch system. Are you thinking it is the automation system causing it to cycle off?
    ps0303's Avatar
    Jul 2011
    FL
    3,691
    So does the HLS light still come on when this happens since you replaced it?
    Paul
