Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: cloudy pool for 5 weeks
    Jun 2013
    Baltimore
    10
    Have had metal issues since I opened the pool. Now its phosphates. Its been cloudy since I opened it 5 weeks ago. I never had these issues. Today my water test is
    Fc 0.2
    Tc 0.3
    Ph 7.4
    T.alk 110
    Cya 25
    Phosphate 2500
    Pool place said everything else was good. Just can't clear it up no matter what they tell me to do.
    30,431
    Re: cloudy pool for 5 weeks
    Your problems are certainly not phosphates and almost as certainly not metals. Mostly you lack chlorine in your pool. You are being "pool-stored"
    If you are interested in what we teach, you will, at some point, need to buy your own good test kit and take charge of your pool. We'll help you get it crystal clear but you are going to have to stay out of that pool store.
    read "The ABC's of Pool Water Chemistry" up in Pool School.....that'll be a good start.
    Aug 2010
    Dallas, TX
    4,052
    Ignore the phosphates. I think this is the third thread about phosphates today.
    The pool place thinks FC of .2 is OK? Time to ignore the pool place, I can give you two good reasons.
    Jun 2013
    Baltimore
    10
    Well I can't keep chlorine in it. It will show up in my test the morning after shocking it and then by evening its just about gone. I have been doing shock just about every other day and nothing changes.
    Aug 2010
    Dallas, TX
    4,052
    What "shock" product are you using?
    I'm suspect of those test numbers. I'm thinking they are not accurate.
    Jun 2013
    Baltimore
    10
    I believe it is Sustain shock. Im not home so im not positive but those are the products they use.
    Aug 2010
    Dallas, TX
    4,052
    The Sustain tablets are calcium hypochlorite. It adds calcium to the pool, and can cause clouding. I used Power Powder Pro (basically the same thing, just Leslie's brand) when I first moved in to bring calcium up. It clouded my water too.
    I don't see a CH number in your test results. If you've been using Sustain, you may have very high CH which will be trouble to keep clear. You'll have to really stay on top of pH and TA.
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    Also, every 'shock' product is primarily some form of chlorine, whether liquid or powder, with additives you may or may not want in your pool. Powder costs much more.
    Chlorine is bleach, and is available at different concentrations. Higher = stronger.
    You personally can't keep chlorine in your particular pool because most likely it is being used up by killing the algae.
    Algae can make your pool cloudy, too. And if not killed, it will grow make your pool green.
    Right now, the algae is growing just as fast, or faster than you are killing it. That's likely another reason why you're not seeing improvement.
    In a virtually unused, perfectly clean and chemically balanced pool, a Free Chlorine level of 3 is pretty much the absolute minimum. A Free Chlorine level of 5 is much better.
    And you post that you are at .2. Are you sure it's not 2 rather than .2?
    If it is .2, that's 1/25th of the amount of chlorine required to maintain.
    If it's really 2, that's less than half necessary to maintain a clean and used pool, and as the level for killing algae is 15, approximately, you are around 1/8th the amount of chlorine required for the shock process.
    Please Read Pool School. Several times. You might start with The Shock Process.
    Don't let them sell you products for Phosphates. While it's true that algae feeds on phosphates and other 'debris' in your pool, if you kill the algae, it won't be there, eating and growing at all.
    You can keep your pantry full of food, but if no one is home to eat it, it just stays there. Right? Same thing with phosphates in your pool.
    Alan in Wellington, FL - near West Palm Beach
    15,200 gal IG, painted plaster, 1988; 200 SqFt cartridge filter, 2013; 1.5 HP 1-speed pump (uprated), 2005; heat pump, 2005;
    soon to repair (dead) SWG AquaRite T-15 cell, 2005, and replace (dead) suction-side cleaner, 2005.
    Almost everything died this winter 2012-'13, and I know we shouldn't complain... but, Arrgh!
    Jun 2013
    Baltimore
    10
    It is .2. And the ch is 320.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    The problem is too low a chlorine level for too long. Go study up on the shock process in pool school, buya whole bunch of bleach, and have at it. You aren;t too late to have a crystal clear sparkly pool that will be the envy of all who see it by Fourth of July, if you start now and follow directions.
    Jun 2013
    Baltimore
    10
    Thank you. Im gonna try the bleach. From what I calculated, I need79 oz. That seems like a lot. Would that be normal
    Aug 2010
    Dallas, TX
    4,052
    That doesn't sound like much to me at all, but my pool is kind of large.
    Keep in mind, for the shock process, you'll need enough bleach to HOLD the shock level. You will likely need many bottles, not one.
    Casey's Avatar
    SW PA
    10,453
    Don't willy nilly dose here and there either. The pool does not need a break. It needs a steady diet of chlorine to shock levels. It's called a process. Don't let up until it's complete.
    Please, do yourself a HUGE favor and buy a TF-100 or a K-2006 test kit. You will need it to complete the shocking process.
    Welcome to TFP! We won't pool store you! We don't own a pool store... just a pool!
    Jun 2013
    Baltimore
    10
    I am now up to 4 bottles of bleach in the pool. Isnt this gonna be a problem on skin or clothes that gets in the pool?
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by jma2013prob
    I am now up to 4 bottles of bleach in the pool. Isn't this gonna be a problem on skin or clothes that gets in the pool?
    Probably not, but how big is your pool? You can safely swim with your pool at it's Cl shock level.
    If you complete your signature block with some details about your pool, it'll help folks give you some more accurate answers. Check out my sig block for an example.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Jun 2013
    Baltimore
    10
    My pool is 21 round and 4 ft. My chlorine levels definitely improved over night and I added a container if bleach this morning. Im anxious to see if I get any results when I get home today.
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    JMA2013,
    According to the Pool Calculator, you've about 10,400 gallons of water in your pool. Once you get the algae killed and the pool cleared, you'll probably be using around a quart of 8% to 10% chlorine bleach per day to maintain safety and cleanliness, just to give you a ballpark idea.
    Getting the algae cleared out will require MUCH more. So we hope you are reading Pool School and using the Shock Process to do so.
    Good Luck!
    Mar 2007
    San Rafael, CA USA
    12,082
    If your pool store or hardware or big box store sells chlorinating liquid, then that's also OK to use. You can easily compare them to determine which is most economical by dividing the price by the fluid ounces (volume) and divide that by the percent (as a fraction) of sodium hypochlorite in the ingredients. As an example, you might find 121 fluid ounces of the newer concentrated Clorox bleach that has 8.25% sodium hypochlorite selling for $3 and want to compare that to 128 fluid ounces (one gallon) of 12.5% chlorinating liquid selling for $4. The Clorox bleach is $3.00/121/0.0825 = 0.30 while the chlorinating liquid is $4.00/128/0.125 = 0.25 so the chlorinating liquid is more economical (and is less weight to carry).
    Jun 2013
    Baltimore
    10
    Oh my goodness.....woke up to a crystal clear pool this morning. Its still not registering high chlorine but it finally looks beautiful. Now I have to stay on top of it. Thank you so much. Nothing like a crystal clear pool.
  20. Back To Top    #20
    Butterfly's Avatar
    South Carolina
    10,045
    Glad your pool is clearing up nicely, but you still need to follow the shock process to a T until you are done shocking.
    See red lines in my sig. You have three tests to pass. pool-school/shocking_your_pool
    Post some pics of the pool for us
    You're done SLAMing when:
