Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Cloudy Pool Water
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Cloudy Pool Water
    I just got my pool opened and refilled last week after painting fiberglass steps with Epoxy paint.
    Chlorine level and PH are good. CYA is still a little low. Hardness is a little high. Everything else is good.
    After one week, the water is still cloudy. Any suggestions to help get it clear.
    16' x 32' Vinyl IG, 15K Gal. (not SWG)
    1 HP Hayward Super-Flo Pump, Pentaire Sand Filter
    Hayward Automatic Chlorinator
    Polaris 380 Pool Cleaner w/booster pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Cloudy Pool Water
    Post your full set of test number please FC, CC, ph, TA, CH, cya. Telling us it is good, doesn't help us help you.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Quote Originally Posted by linen
    At work right now, but from what I can remember yesterday
    FC - ?
    CC - 3.5
    PH - 7.5
    TA - 150
    CH - ?
    CYA - 40
    These are what I best remember. I don't have a FC reading and remember the Calcium Hardness was around 150-200.
    TA was pretty high, can't remember the number.
    I'll post results tonight.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Are you certain of that CC number? If yes, then you need to do the shocking process (since CC is >0.5 ppm) and the cloudiness is very likely will clear up as well. See:http://www.troublefreepool.com/pool-...king_your_pool
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    I know you will flame me for this, but the only tester I have right now is the HTH Chlorine and PH liquid tester and some 6-way strips.
    The chlorine (red) shows the chlorine level is ideal at 3.5 and the PH (yellow) ideal at 7.5-7.8. Both are within the ideal range.
    The other reading are from test strips.
    Like I said before, I am posting from work based on what I remember from testing yesterday. I will retest later today when I get home.
    and yes - I am going to order the K-2006 kit.
    Best I can do right now though.
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Quote Originally Posted by BB BMW
    You've got a big boy pool, you need a big boy tester. Go with the TF-100, and you'll have much more reagents to do more tests, which you'll need to take control of your pool properly.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    OK just tested the water with strips and liquid regents today at 6:00pm CDT.
    Strips:
    FC = 0/1
    PH = 7.5-7.8
    TA = 180
    CYA = 30-50
    (The strips do not measure CC)
    I know, need a Taylor kit
    Liquid Regents:
    FC = 1.0-1.5
    CC = 1.5
    PH = 7.6
    Ordered A Taylor K-2006, but it has not arrived yet.
    The water is a little clearer tonight and I can see the bottom better. Had a bit of rain this afternoon. It needs another vacuum and brushing.
    Jan 2013
    Houston, TX
    1,079
    Liquid Regents:
    FC = 1.0-1.5
    CC = 1.5
    PH = 7.6
    Time for the shock process for you. CC is greater than 1.5
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Quote Originally Posted by karmabiker
    Liquid Regents:
    FC = 1.0-1.5
    CC = 1.5
    PH = 7.6
    So I need to start adding bleach until I bring the FC up to the shock level on the Chlorine/CYA Chart, based on my CYA level?
    Based on my readings, CYA is somewhere between 30-40 and FC at 1.0-1.5 I need to bring the chlorine up to about 14 or 15.
    Should I add bleach over a period of time or mostly all at once?
    Jun 2012
    Howell, NJ
    977
    Add as much bleach as is required to get up to shock level. When you get the K-2006, you will have to be testing the FC level up to once an hour and dosing to shock level.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I bet it isn't. Strips are almost always wrong on cya. Assuming that level likely won't hurt anything, then when you get the new kit (by the way the tf-100 ships fastest typically and is the best value) you can find out what it really is and go from there.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Do strips usually read highr or lower?
    Jun 2012
    Howell, NJ
    977
    I don't think it is either. Strips generally have no connection to reality.
    John
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    OK
    got test kit and retested my cloudy pool water. Here are the new readings
    CYA = less than 30 (dot did not disappear) adding CYA
    FC = 1 (adding bleach)
    CC = 0
    PH = 7.2
    TA = 90
    CH = 120
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Any new suggestions based on latest numbers?
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I would start the shock process, even though you have no CC, you still have cloudy water. The CYA you are adding will probably not show up for a few days to a week, so just assume it is in there. I would be careful not to overshoot on the CYA as well, easy to add... not as easy to lower.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Quote Originally Posted by dattia
    I just did the shock process thursday and brushed and vacuumed friday.
    Do you think I need to do it again?
    Jun 2012
    Howell, NJ
    977
    If your pool is still cloudy, you never finished the shock process. There are 3 criteria to meet, <1 ppm FC loss overnight, <.5ppm CC, and the pool is clear.
    John
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    No offense but you need to read the shock process instructions in pool school again. Shouldn't take you too long to finish and remember you can swim up to shock level for your CYA level.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
  20. Back To Top    #20
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    You can perform an OCLT (Overnight Chlorine Loss Test) tonight if you are able. If you lose chlorine overnight, it means something in the water is consuming the chlorine in the absence of sunlight. If you do not lose any chlorine, it is probably just a matter of giving your filter time to do it's job. Sand filters are very reliable, albeit a little slower than other means of filtration. You can boost your filters ability to filter finer particulate by adding DE or a DE alternative to your filter.
    27' round AG
