Thread: Check Valve and Flow rate
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    I have a question regarding a check valve that was recently added to plumbing. Per Pentair recommendations, we had check valve installed between filter and IC40. It is a spring valve and installed vertically. I have noticed a reduced flow rate and wanted to confirm that this could be caused by check valve. I would think that debris wouldn't be a problem since it is downstream from filter so is it just the inherent nature of the valve?
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    Re: Check Valve and Flow rate
    All check valves reduce the water flow at least a little. Spring style check valves do so more than other kinds of check valves. Flap style check valves are the best, ie have the least effect on the flow rate.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by Ksnewman
    How did you notice the reduced flow rate? Out of the return or flow meter?
    Has the filter pressure changed?
    Mark
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Quote Originally Posted by mas985
    I really didn't notice much on filter pressure. Where I noticed was that I was able to have my pump set at 1100 RPM and the SWG was happy with flow and chlorine production. After check valve was installed, this was not enough flow to keep SWG happy. I had to increase to 1250 or so. Also, I had the waterfall set on a low flow option for a "softer sound" of water falling and after check valve, the water wasn't flowing nearly enough to create that effect so I have had to increase that as well. My filter pressure may have gone up 1 psi but no more.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Ok, that makes sense. The SWG was probably borderline at 1100 RPM and the added head loss dropped it done some.
    Mark
