Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: A quick request
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    A quick request
    My pool is a vinyl liner in ground total calculated 31,590 Gal. (rounding to 32,000) with a sand filter running 24/7 (Hayward pro series model S220T) and a 1 HP. pump motor. I am using a Taylor K 2006 test kit. After reading all of Pool School and multiple post I wanted to ask your suggestions. My ordeal started on 6/13/2013. My FC level was 0 My PH. was above 8.0 my TA. was 140 My CH was 8.0 My CYA was 30 35 range.
    Now I see that after 7 days of doing (as best I could) what was instructed here all looks pretty well except for some continued cloudy water. I found that I way backwashing way too often and have corrected that. My current readings are....................
    FC. 2.6 (I know that needs to come up)
    CC. 0.2 if that probably a bit lower
    PH. 7.4
    TA. Around 75 (On the kit it shows somewhere between 70 and 80)
    CH. shows 0 (best I could determine)
    CYA. is closer to 30 than 40 (best I could determine)
    So, I guess I would please ask what I should do if anything at this point. thank you for your continued efforts ! With best regards, vsat88.
    Vinyl liner in ground. Pool volume 27,000 Gal. Sand filter. Pump runs 365 days a year 24/7 (Hayward pro series model S220T 1 HP. motor). Taylor K 2006 test kit. I use the BBB way found here at TFP. The only thing I buy from the pool store is CYA.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: A quick request
    Sounds like you need to complete a shock process. To be sure, get your chlorine up to target as per the Chlorine/CYA chart. Check out pool school for doing an over night free chlorine loss test (OCLT) and go from there. If needed the shock process is also in Pool School. I question the CH reading and would suggest a re-test to eliminate test error possiblities.
    Welcome to TFP! Hang in there and we will help you out.
    Essential Links:
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Re: A quick request
    Your free chlorine is way low .... it's too low for regular maintenance and way way too low for the shock process.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    Re: A quick request
    Quote Originally Posted by Brushpup
    Sounds like you need to complete a shock process. I question the CH reading and would suggest a re-test to eliminate test error possiblities.
    CH. is 20 My bad ! Thanks, and I will hang in and do as I am told. I believe in you Cats !
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    Re: A quick request
    So to be clear I have remained at a 12-14 PPM shock level till day before yesterday and allowed it to fall to 3.0 too soon and should bring it back up to shock level ?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: A quick request
    I added more info to my post before you posted. Sorry about that, but check out what I said above and lets see what happens. Please put your pool info in your sig and it will help us help you quicker.
    Bring it up to shock level before sundown, test after sundown and do the OCLT. I don't know if you "let it fall" too soon for sure without knowing your over night loss. You may need more shock time, but lets see...
    Essential Links:
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    Re: A quick request
    OCLT is at 0.5 Max. Last two nights in a row. I test at or just before sundown then early AM next day. That is why I allowed the levels to drop. I thought that I read that was when to do so at 0.5 to 0 loss . My bad. I will bring it up before dark tonight as you suggest. Better safe than really sorry as I have really put a lot of effort in this and I respect highly your suggestions. Added my pool info to my sig..I hope. With best regards, vsat88. and BTW I am just guessing but you do mean overnight chlorine loss test by OCLT. Right ?
    Nov 2011
    Albany, NY
    495
    Re: A quick request
    Quote Originally Posted by vsat88
    There are 3 criteria ... CC of .5 or less, OCLT with a loss of less than 1 ppm AND clear water.
    So you still need to follow the shock process until you meet all 3
    Haywood Sand Filter
    Vinyl Liner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: A quick request
    Quote Originally Posted by ship of fools
    He is right, and You might be just on the verge of being done. Sometimes clearing just takes a little time.
    Essential Links:
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    Re: A quick request
    Will do ! you Cats are awesome ! Thanks !!
    Jun 2012
    Howell, NJ
    977
    Re: A quick request
    Since you passed the first 2 criteria, have you considered adding DE to your sand filter to help speed up the process? There is an article in pool school about it. Also, for chlorine testing, you can use a 10 mL sample instead of a 25 mL sample.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    Re: A quick request
    Quote Originally Posted by JohnN
    Thanks and I have thought of that however I am a NooB so I thought I might ought keep it as simple as possible. H.D. has DE so I may trip down today if things do not improve. I have been using the 10 ml sample and even though I have I am starting to get very low on regent so I will have to get a bottle today at the "fool store". Thank you ! With best regard, vsat88.
    After Shock last night FC=24.5 CC.=0.5 (at 10:30 PM)
    AM today. FC = 21.0 CC.=0.5 (at 6:30 AM)
    BTW..We did have some rain last nite, not a lot but some...
    Please advise .... Thanks all !
    30,431
    Re: A quick request
    A loss of 3.5 ppm FC overnight means you still have organics in your pool. Keep the faith and continue the shock process.
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    Re: A quick request
    I will. Going to the store now for replenishment. Should I just keep it at 24.5 25 PPM ?
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    Re: A quick request
    BTW, my CYA says anything 16 or above is at shock level...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: A quick request
    It might go a little faster if you do. I go by the chart from Richard (chemgeek) and I've gone higher. When I did, it sped things up for me. Whatever you do, don't let it get below shock level.
    Essential Links:
    Jun 2012
    Howell, NJ
    977
    Re: A quick request
    Just want to let you know that the pool store probably won't have the correct reagents. Most of the time they sell the DPD test kit, which is not the same as the FAS-DPD kit.
    John
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    Re: A quick request
    JohN thanks for the warning, I called before I went and found it ! And went to H.D. and bought 25 lbs. D.E. and followed the directions I found here as well. The pool is really beginning to clear even before the D.E. was added due to the suggestions from Brushpup ! I will continue to update and follow suggestions ! Thanks again. With best regards, vsat88.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: A quick request
    Just a little while longer I bet.
    Essential Links:
  20. Back To Top    #20
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    Re: A quick request
    You were right! Halljuigh! Lol losss less than 1ppm FC. Last night. Pool so clear you can see a quarter at the bottom of the deep end. And CC. 0.0 ... All I can say is thanks so much. I actually did pray last night and turn it over to my H.P. because I did not know how much longer I could hang in. So tbanks again and best regards to all here! I will post back as soon as possible with further results.
