Results 1 to 15 of 15
Thread: New to my pool- Ph 7.2.... raise it or leave it?
    May 2013
    Fort Lauderdale, FL
    423
    My Ph has been 7.2 for the week I've been at our new house with pool. FC is between 2-4. I just ordered some Borax. Should I try and raise it to 7.5, or just let it ride?
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: New to my pool- Ph 7.2.... raise it or leave it?
    Let it ride, for now.
    What are you testing with? Or are you relying on a pool store?
    May 2013
    Fort Lauderdale, FL
    423
    Just got a TF100 kit but also have a Leslie deluxe kit- both have the same Ph test.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    If the TA is over 100, the pH will be climbing soon enough.
    May 2013
    Fort Lauderdale, FL
    423
    TA is 90.... I'm going to dive into the big test kit and check the calcium level- prior owner used nothing but Leslie's shock granules and 3" tabs. But pool has only been open for a month, so maybe it hasn't risen too much yet.
    38,521
    Post up a full set of test results as that could impact our recommendations ... although likely the pH is fine.
    What are you using to add chlorine to the water?
    May 2013
    Fort Lauderdale, FL
    423
    I'll do a full test today or tomorrow. So far (had the pool for a week) been using the leslie chlorine shock granuales (73% hypo) and leaving 3, 3" tabs in a floater. I know, bad bad. I'm even more mad she (prior owner) drug me down to the pool store had me shell out several hundred $$$ on chemicals during our house "turn over". I'm going to start using clorox as soon as I can get down to costco. I have a gallon jug of clorox outdoor from home depot- I can use that in the mean time- will have to see what % it is and run it in the pool calculator.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    NO on the clorox outdoor, unless you LIKE foamy cloudy water. Outdoor contains detergents, that WILL make a mess in your pool.
    May 2013
    Fort Lauderdale, FL
    423
    Ah, good catch! I haven't read the label yet on the bottle. I'll hold off until I get regular clorox then.
    Jul 2012
    Herndon, VA
    419
    Quote Originally Posted by zimm
    DO NOT USE THE OUTDOOR BLEACH!!!! It will cloud your pool! Read here:
    just-dumb-wrong-type-of-bleach-cloudy-water-t64111.html
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    38,521
    The tablets are acidic and may continue to drive the pH and TA down. You really need to test the CYA and see if you are doing yourself a disservice by their continued use.
    May 2013
    Fort Lauderdale, FL
    423
    Okay, Just got done playing with my TF100 test kit. Not exactly sure on the CYA though- the black dot never "disappears" but it goes to a grey around 90-100.
    So....
    FC 2
    Ph 7.2
    TA 110 (up from 90)
    CH 450
    CYA 90
    What should I adjust? I pulled out the chlorine tabs. Need to get some clorox ASAP.
    38,521
    Wait ... so did you fill the tube up completely and were still able to see the black dot? Or did you stop adding solution too early?
    Review this:
    extended-test-kit-directions-t25081.html#p206397
    May 2013
    Fort Lauderdale, FL
    423
    I read the thread and looked at the pics. I didn't loose the black dot at all with the full sample. Does that mean cya of 0?
    38,521
    That means it is between 0 and 20ppm.
    The pucks you have used have added some CYA so it is not zero. You need to get the CYA up to at least 30ppm to protect your chlorine.
