Thread: Bumping DE Filiter
    Jun 2013
    kouts indiana
    9
    Bumping DE Filiter
    How often would one have to bump filter while shocking a pool that went the winter with out being covered? I cleaned filiter with muratic acid in a bucket of water. Put back together and charged with 4 lbs of de. water is cloudy can only see 2-3 feet down, i have to bump every hour or 2. Does that seem normally?
    1600 gal AG Oval
    18x34
    1 1/2 HP hay 4 lb de 38 GPM
    Roover vac.
    pool owner 19 years
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: Bumping DE Filiter
    Yes. Sounds about right. DE is very good at keeping a clean pool clean. It's the nature of the beast when fighting pool problems.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
