Planning My Pool Slide
crokett
677
Hillsborough, NC
So here is the ladder and slide.... sorry for not embedding, I have not figured out in SkyDrive how to get the .jpg link. I will use aluminum angle to bolt the ladder feet to the deck. To connect the slide to the ladder, do you think the slide still be strong enough if I cut away enough of the sides at the top so I can bolt the slide to the top step on the ladder? I also need a way to get the foot of the slide out over the edge of the pool. I don't want something resting on the top of the wall, so I want to cantilver from the deck. I could use treated or possibly square aluminum tube. Would aluminum be strong enough? It would not be exposed.
Here is the slide and ladder mocked up.
http://sdrv.ms/17yLcPi
Here is the foot of the slide.
http://sdrv.ms/17yLkhR
Here is the top looking down. I would cut the sides back enough to let the top edge sit on the top step on the ladder. My other thought was leave the slide as-is and use aluminum tube bolted to the legs under the top step and the slide gets bolted to that through the sides.
http://sdrv.ms/17yLoya
