Results 1 to 7 of 7
Thread: Planning My Pool Slide
    Jul 2007
    Hillsborough, NC
    525
    So here is the ladder and slide.... sorry for not embedding, I have not figured out in SkyDrive how to get the .jpg link. I will use aluminum angle to bolt the ladder feet to the deck. To connect the slide to the ladder, do you think the slide still be strong enough if I cut away enough of the sides at the top so I can bolt the slide to the top step on the ladder? I also need a way to get the foot of the slide out over the edge of the pool. I don't want something resting on the top of the wall, so I want to cantilver from the deck. I could use treated or possibly square aluminum tube. Would aluminum be strong enough? It would not be exposed.
    Here is the slide and ladder mocked up.
    http://sdrv.ms/17yLcPi
    Here is the foot of the slide.
    http://sdrv.ms/17yLkhR
    Here is the top looking down. I would cut the sides back enough to let the top edge sit on the top step on the ladder. My other thought was leave the slide as-is and use aluminum tube bolted to the legs under the top step and the slide gets bolted to that through the sides.
    http://sdrv.ms/17yLoya
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    38,284
    Re: Planning My Pool Slide
    FYI, those links do not work for me at all.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    They work for me.
    Jul 2007
    Hillsborough, NC
    525
    Hmmm no one else has reported problems with picture links. What browser are you using?
    38,284
    Chrome ... could be firewall, but I usually do not see this when it is the firewall:
    This webpage is not available
    The webpage at https://skydrive.live.com/redir?resid=8 ... Xht8XPsO2A might be temporarily down or it may have moved permanently to a new web address.
    Error 111 (net::ERR_TUNNEL_CONNECTION_FAILED): Unknown error.
    Jul 2007
    Hillsborough, NC
    525
    hmm I guess it is you. It works for me in Chrome, FF and IE. I don't use Chrome much, it causes my video card to reset. I had the problem fixed but then a Chrome upgrade broke it again.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I use Chrome, they've worked every time for me.
