Thread: Filters for Well Water-Need to top off pool
    Jun 2012
    Hudson Ohio
    47
    We have well water. We had the pool filled with water we had delivered. The pool was accidentley drained a little low after the last big rain. We need to add about 400 gallons to get the water at an appropriate level for the skimmer. I found a filter online that it suppose to fillter out the iron and minerals. I don't want to mess up my "beautiful" sparkly pool. Any thoughts from well water users?
    18 x 54 Sharkline Matrix pool. 7800 gallons.
    Pentair Optiflo 1 1/2 HP 2 speed pump
    Pentair Clean and Clear 150 Sq Ft cartridge filter
    Hayward H100ID Heater. Purchased all from Poolsupplyworld. TF-100 TEST KIT
    22,551
    Re: Filters for Well Water-Need to top off pool
    Do you have a water softener? If so, then use it to refill the pool.
    Jun 2012
    Hudson Ohio
    47
    We do have a water softener also. My husband has a fear of adding any metals or rusty water to the pool, even with pre-filters. Just don't want to mess up the water.
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    Yes run it thru your system, you will be fine. I have filled my pool 3 times thru my system.
    Dough Boy 12' x 24' Oval
    Wedding Cake Steps
    1500 SF Timber Tech Composite Decking
    Video of my pool and retaining wall....Above Ground Pool Ideas - YouTube
    Jun 2012
    Hudson Ohio
    47
    Johnnysnok..Did you fill just with the water softener? Any other pre-filters?
