Results 1 to 18 of 18
Thread: Test Results -easiest way to raise PH and TA?
    Got my water tested yesterday with these results
    FAC 3
    TAC 3
    Calcium hardness 490
    CYA 99
    TA 80
    PH 7.0
    TDS 600
    PHO 2500
    Pool store says I need to drain about 1.5 ft of my water and refill to get caclium down...also need to raise PH and TA? What is the best way?
    built 4/08/2000 16 x32 460 Sq FT Pool 16,000 gallons 3.5 ft 5 ft 3.5 ft sport pool
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Test Results -easiest way to raise PH and TA?
    Although I don't think you need to raise your TA level any, use plain old baking soda from the grocery store. Use pool calculator to determine how much to use and the effect it will have. You can simply aereate the pool to raise PH.
    30,432
    Your overlooking your biggest issue. Your CYA is too high and should be reduced down to around 50 ppm. YOu should keep your FC up around 8 ppm until you lower CYA.
    read "The ABC's of Pool Water Chemistry" up in Pool School
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    99 is the pool store code word for "off the scale" when it comes to CYA. I wouldn't be surprised if it was more like 200. The best way to know for sure is to test it yourself with a proper test kit. A distant second place would be to mix tap water and pool water 50-50 and take that sample to the store and see what they get, then double it.
    Ok so how much water would I need to drain and refill to get my CYA down to a better level? Looks like thats what i need to do with the calcium as well.
    On PH, just by running my pumps longer it will raise PH?
    30,432
    Water replacement is a direct percentage of CYA....remove 1/2 your water and you remove 1/2 your CYA.
    I would leave pH alone. If you have been using pucks, stop using them and your pH will come up. Leave your TA alone as well.
    At some point, you must decide whether to take charge of your own pool (get your own good kit) or continue to get it tested at the pool store. Right now, you are not getting very good advice from the pool store and I doubt their testing is very good, either.
    I actually have one of your kits, and I have used it. I just have doubts that I use it correctly sometimes so end up back at the pool store.
    I am using pucks in a chlorinator.
    I have never drained my pool down, I am curious as to how I would do it.....What is draining once my skimmers are above the water line?
    Aug 2010
    Dallas, TX
    4,052
    The pucks in the chlorinator are how your CYA got so high.
    You can rent a submersible pump to drain water.
    Or put the vac hose on and put filter to waste
    Surely there is way to turn off the skimmers and drain from the main ?
    38,514
    Quote Originally Posted by 4x4tx
    Only if your pool was built that way ... my 2 pools have not been because the floor was plumbed to the skimmer and then from the skimmer to the pump. The diverters that are put in the skimmer are not airtight, so you end up pulling in air once the water gets below the skimmer.
    If your floor is plumbed to the pump with a valve to select skimmer / floor ... then you can isolate the floor better and likely can do it with the pool pump.
    30,432
    Out of the Frying Pan and into the Fire.
    There are hundreds of people on this forum that will help you with your own testing....me included.
    Drained the pool down maybe ft ft.5 and let pump run all night last night.
    Took water sample today and got these results back.
    FAC 4
    TAC 4
    CH 350
    CYA 60
    TA 90
    PH 7.4
    TDS 600
    Phos 300
    Now curious how my CYA dropped from 99 to 60 with only at most a 2ft drain? Assuming PH went up because I ran the pump all night?
    [attachment=0:1vrzy8o5]ImageUploadedByTapatalk1372473571.043411.jpg[/attachment:1vrzy8o5]pic
    Richard320's Avatar
    Jan 2010
    19,058
    FAC 4
    TAC 4
    CH 350
    CYA 60
    TA 90
    PH 7.4
    TDS 600
    Phos 300
    Because Pool Store Testing is notoriously wrong. Especially the CYA test.
    38,514
    What Richard said. There was just another thread where the CYA jumped from like 60 to 140 for no reason.
    Ok for a 16000 gal pool, how much chlorox would I need to use weekly or monthly? I am ready to make the change. I cut off the pucks this weekend so I need to do something next couple of days.
    Richard320's Avatar
    Jan 2010
    19,058
    Think daily.
    The way to know is by testing and calculating the proper dose for your CYA level using http://www.poolcalculator.com/ After a couple weeks, you will know your pool's appetite and will be able to predict pretty accurately what you'll see when you test and what the dose will be.
