Results 1 to 7 of 7
Thread: Black grease in skimmer
    Jun 2013
    East TN
    309
    Keep getting the black greasy looking substance in the skimmer. Mostly at the water line but some where the basket or attachment for the vacuum hose meets the skimmer below the water line. Ive read its a pretty common problem and couldnt find a definitive answer on what it is.
    Anyone ever try the scumball thing to get rid of it or anything else?
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Black grease in skimmer
    Magic Eraser
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok, but what is this substance?
    Essential Links:
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I think mine is sunscreen.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2013
    East TN
    309
    I cleaned it off yesterday and now its right back in the same spot. I cleaned it off with straight bleach although its right at or below the water line (dilution). There was barely some black still there when I was done because it would not come off.
    I was thinking about why it is only in the skimmer and I would presume it is oil of some kind because if I watch the water flow in the skimmer the very top layer (which would be oil) does not seem to get sucked down and if you had an oil on the top of the water it would just stagnate in the skimmer because it can not go out of the skimmer or will not go down the hole. If that is true then there will always be an oil build up in the skimmer.
    rdw1961's Avatar
    May 2012
    Mount Pleasant, PA
    17
    I always thought it was pollen in my skimmer. When the solar cover is on my pool, it will take several days to build up, but when the cover is off and more water surface is exposed, it will build up rather quickly in the skimmer.
    24' Above Ground Round vinyl
    DE Filter pump 1HP
    Flow Rate 39GPM
    14700 gallon
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    Ditto on sunscreen....I get it too, just scrub it off.
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
