Results 1 to 7 of 7
Thread: Chlorine Dispensers?
    May 2013
    Round Rock, TX
    138
    The PB has a chlorine dispenser as part of the equipment for our build in a couple weeks. I'm thinking of having him remove it and credit me the $ for something else such as a Stenner pump. Any reason why I should keep the dispenser?
    35'x16' IG geometric with 8'x6' spa (16.5K gallons); White Diamond Pebblesheen w/Abalone Shells; Jandy 460 cartridge filter; Jandy 2HP E pump; Jandy 400K heater; Water Tech Blue Diamond Pro; TF-100 w/SpeedStir
    May 2013
    North East Ohio
    959
    Re: Chlorine Dispensers?
    I took mine off and put in a stenner pump...
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The only reason might be to use trichlor pucks when taking vacations, but a $10 floater will work good enough for that.
    May 2013
    North East Ohio
    959
    Quote Originally Posted by Isaac-1
    But if you have a stunner pump...every day it auto pumps chlorine...no need for dispenser on vacation.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Tablet feeders are not that expensive, you cant get a perfectly adequate one for $50 and frankly find them more practical than floaters for a few reasons, but I suppose it depends on the pool.
    If you're building a gunite pool the acidic tabs will be particularly more useful than straight chlorine (at the beginning) but that's just another angle to view things from... to each his own I suppose
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It is just my experience that pumps and such can go wrong during a vacation, floaters are about foolproof
    May 2013
    North East Ohio
    959
    Yep I agree, pumps can fail...but so can SWG's fail as well. I guess there is no 100% foolproof method, it is all about what you are comfortable with.
