Results 1 to 9 of 9
Thread: I thought I saw Algae?? cc 0
    Jan 2011
    Huntsville, AL
    67
    I was just getting ready to jump in after doing some yard work and noticed a few blotches of green in the deep end on the surface of the liner. I thought oh ****! I had not tested in several days of sunshine. My Chlorine generator kept the pool at about FC 10 so I turned it down last week.
    I ran in and got the test kit and:
    FC 2.0
    CC 0
    PH 7.6
    TA 50
    CYA 60
    I ran and turn the generator on 100% and dumped 1 1/2 gallons of bleach (all i had here) in.
    Any chance that I really have algae? I have never seen it before and maybe I'm paranoid but I thought the water felt a little slimy.
    I will retest in the am.
    16 x 32 inground with Tara Liner, 1 skimmer, 3 returns,
    1HP Hayward Super Pump
    Hayward Sand Filter
    Polaris 280 w booster pump
    Hayward SWG & Aqua Plus
    k-2006 Test Kit
    30,432
    Re: I thought I saw Algae?? cc 0
    Sure sounds like it. get your pool brush and brush it up off the bottom or anywhere you think it might be. The chlorine you added will probably get it quickly and you will not have to shock.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Make sure you test more often. The FC of 2 is to low for a CYA level of 60.
    Jeff
    Casey's Avatar
    SW PA
    10,461
    Use bleach to raise your FC and turn the generator down so you don't ruin the cell.
    Jan 2011
    Huntsville, AL
    67
    Got up this morning and FC at 10 & CC still 0. I am putting the chlorine generator back to 50% and I will do the overnight loss test tonight before shocking..............thanks everyone.
    Hayward Sand Filter
    k-2006 Test Kit
    Jun 2012
    Howell, NJ
    977
    Make sure the SWG is off for the OCLT.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jan 2011
    Huntsville, AL
    67
    I did the OCLT. Last night FC was 11.5 and this morning it was 9.5. A couple of things that I may have done wrong. First, I did the test last night within 2 minutes of shutting off chlorine generator. Second, I left in polaris with a few leaves in the pool. Any chance that the generator, polaris, a few bugs, and a frog would have skewed the test? Water is crystal clear and no signs of algae. Before shocking, Any harm in waiting and doing the test again tonight and ruling out my mistakes?
    Hayward Sand Filter
    k-2006 Test Kit
    30,432
    None at all. Your eyes are probably a better judge, in this case. If you see no visible signs of algae and your water is crystal clear, you are probably good to go.
    If it was my pool, I would still keep the FC elevated for another 24-48 hours and then let it come back to normal. Of course, if you see the algae again, it's time to shock.
    Jan 2011
    Huntsville, AL
    67
    Thanks Duraleigh!
    Hayward Sand Filter
    k-2006 Test Kit
