Thread: Converting to swg
    Converting to swg
    I will be converting to a swg pool. My numbers are as followed
    16x32 vinyl lined inground
    21000 gal
    Ph 7.5
    Fc 2
    Ta 120
    Cya 35
    Do I need to change anything other than the cya before adding salt ?
    21000 gal vinyl lined in ground
    36 sq. ft. DE filter with Hayward 1.5hp VSP
    SWG chlorine
    Massachusetts
    30,415
    Re: Converting to swg
    Sounds like you are ready. Go ahead and bump your FC up to around 5 ppm (with bleach) so your SWG won't have to work hard trying to bring it up from 2.
    Great! Been reading all over the internet (until I found this site) that I am suppose to drain and fill with fresh water first. Didn't make sense. Are my numbers good to maintain at those levels after or should I adjust something ?
    SWG chlorine
    Massachusetts
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    416
    Just check your salt level first before adding salt.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
