Thread: Pump and filter questions
    I have an above ground pool that is about 20,000 gallons. It came with a 1.5hp Astral pump and a sand filter, which I do not know it's size. I run this pump for 2 four hour session each day during the season. This causes a significant rise in the electrical bill. I have been thinking of replacing it with a smaller pump, but I am not sure what size to get, or if I need to replace the filter as well.
    When I opened the pool this season, the pump is squealing as if it is about to die. It has been running 24/7 for 2 weeks during the opening phase, however. So I feel as if I am going to have to do something soon. The local pool store discouraged me from getting a 3/4hp and said not to go any smaller then 1hp. I only have one return on this pool and it shoots like a rocket.
    So, can I just replace the pump with a smaller one? How small?
    Or, do I have to get a properly matched filter as well? How do I determine the size of my existing filter?
    Hurricane Rita did not kill me, but she killed my pool!
    Intex 36'X18'x52" "elliptical pool"/ Hayward 220 filter/1HP pump 14,364 gal, or so
    May 2008
    South Jersey
    While I can't comment on the sizing of the pump (there are many others on here that I'm sure will give you good advice) I can tell you that a pool store might not be the best place to get a motor. When mine went bad (sqealing lead to siezure) I found a company that specialized in electric motors. I took my motor in and got a replacement for MUCH less than what the pool store was asking for lesser quality motor.
    I don't know if this is the norm or not, but that was my experience.
    17x35 Inground Vinyl Liner
    26,000 Gallons
    Nautilus DE Filter
    Pacfab Challenger Pump
    Mar 2007
    Coastalish 'down easter'
    Sean, your experience, unfortunately, is typical
    Thewayne, without even knowing the size of the filter I will tell you to get the 3/4 hp motor - you don't need the whole pump - a motor 'swap out' is fairly easy if you have the tools to do it and are even slightly handy. The smaller motor will save you $ on electricity and will surely be sufficient for your pool (and probably allow for better filtration!) If you get just the motor as I suggest, also pick up a new "shaft seal assembly" - those things don't react well to being removed and reinstalled and can cause real trouble (like needing a new motor) if they fail
    This is a busy time of year for me, but I always try to keep track of the folks I've offered advice to, so if you have any questions about doing the change-out, just ask and I'll help you as much as I can without actually being in your yard
    Luv& Luk
    Where should I look for one of these motors, and what brand?
