Results 1 to 13 of 13
Thread: Pool Temps Rising - Aluminum Foil Solar Reflector?
    Aug 2011
    Houston Texas
    17
    So the heat has taken off the last couple of weeks here in Texas and the water temp has shot from around 84 to over 91. Recalling how last summer was and how the water ceased to be refreshing at severl points, I was wondering if there is any reason a PVC pipe framework with aluminum foil wrapped about it would not help prevent the temp from rising so much during the day (sections of chopped pool noodle slipped on the PVC would provide buoyancy). My main conern is whether or not there will be a reaction between the chlorinated water and the foil and ultimately winding up with metal in my water (I presume that would be considered bad since copper and other metals are treated as such).
    Since I am not the sharpest tool in the shed, I would imagine that someone else has likely had a similar idea, but maybe not enough people live anywhere that it is hot enough to both doing anything beyond running the pump longer at night and or water works to cool everything. I was thinking something that would be easy to toss in the pool and almost just as easy to remove, but that would limit the amount of sunlight allowed into the pool during the day (think the solar rings they seel as a non-solid pool cover, but completely reflective).
    Regards,
    Steven
    Circa 2000 - IG 20k Gallon Plaster/Gunite Pool - Painted (though much of the paint has worn back down to the plaster)
    FNS Plus DE Filter (60 sq ft?) - Formerly paired with 3/4 hp Pentair Challenger pump
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Pool Temps Rising - Aluminum Foil Solar Reflector?
    Have you tried using a fountain ?
    Jeff
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    I am in the same boat as you right down the road on IH-10. I use a fountain. My pool hit 90 a week or so ago. I now have it down to 84. Thats about what it stayed last year in the heat of the summer. Just watch your ph. I can run mine 8 hours a day for three days before I have to adjust ph.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Aug 2011
    Houston Texas
    17
    Quote Originally Posted by jcowart
    My backyard is relatively small, and options limited. What kind of a fountain do you have? I realize that it is not as pretty, but I was kind of operating under the premise of avoid the heat in the first place, instead of incurring the expense of a fountain, the electricity to run it, and the acid to counter it. That said, if the fountain is feasible for my setup, I am open to pursuing it. Keeping it in the mid to upper 80's sounds very nice.
    May 2013
    Massachusetts
    148
    People here in the ne would kill to have your problems, lol!
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    There's alot of DyI fountains on here. They make them out of PVC and run them off the return with a valve so you can adjust the fountain and still use your return jet.
    Jeff
    38,521
    You are not understanding what is meant by fountain. Search the site.
    Many people just put some pieces of PVC together and stick it in the return jet so the water goes spraying into the air and back into the pool. It is just using your regular pool pump.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I forgot about that one nice job harleysilo !!!
    Jeff
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Search for pool fountain. It screws into where your eyeball return is and sprays into the air and back into the pool. When you aerate the water it will bring the ph up. Thats also how you lower your TA. Muriatic acid brings both TA and PH down then you aerate to bring the ph back up. My father in laws is 1 1/2" male thread to a 90, then 1/2" bushing, 10" pipe, to a shower head.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Quote Originally Posted by weird_tolkienish_f
    I would prefer cooler temps. I am 10' above sea level "Gulf of Mexico" so the humidity is what kills us. It has averaged 100+ heat index for a while. 80 to 90 degree pool water feels great for the first 10 or so minutes.
    Aug 2011
    Houston Texas
    17
    I will go jump in the pool again to confirm, but I do not believe that my return jets have threads. Whomever built my pool did it as cheaply as possible, one pump, one filter, the skimmer basket and pipe at the bottom of the deep end feed the pump, and 3 returns pump it back out to the pool (it looks like there used to be a fourth but it has been plugged - when I unplugged it, it was not pumping so who knows what happened there). The lack of threads on the returns limits my options for the fountains (which I had googled), but I think I may be stuck until the plaster gets redone. At that point I can have proper eyeballs put in, a fill line so I don't have to run a hose across the yard, and all that good stuff... Back to the original question though, does anyone know if there will be any problems with aluminum coming in contact with the water?
    May 2013
    Massachusetts
    148
    I remember last year there was a 24 hour period where I managed to get my pool temp over 80. I was pretty psyched. Didn't last long.
    DE, Hayward Filter
    Loud pump
