Results 1 to 8 of 8
Thread: New Here..
    New Here..
    Hi! I live in NC we use well water. Our pool has 18,300 gallons and is an above ground with vinyl liner. We have a sand filter
    We had extremely cloudy pool and an awful chlorine demand. We finally got the demand under control. It was so cloudy you couldn't see the 3rd step. It was a blue white cloudy. Well we flocked this weekend and now the pool is crystal clear.
    I took a sample to the pool store and here are the readings
    FC: 10.56
    CC:0
    PH: 7.8 (added 2.5 lbs ph decreaser per pool store)
    TA:106
    CH: 346
    CYA: 100
    The cya was around 120 before we drained part of the pool and refilled. We are limited on the amount we can drain and refill at a time due to the well. We are going to start the liquid chlorine so we don't add more cya to the water.
    We have been pool stored. Are we on the right track or what do we need to do?
    The pool store said it was ok just not recommened to swim with high chlorine. But when I looked at the CYA chart we are in the middle where ideal would be 12. Is it safe to swim in? I have 3 kids ( 12, 9, and 7)
    Thanks
    AG-vinyl, 18,300 gallons, pool is 5 yr old, sand filter, one speed motor,
    Casey's Avatar
    SW PA
    10,444
    Re: New Here..
    Your CYA/Chlorine ratio is safe to swim in, although you should really consider another partial drain/refill as you will be adding a lot of chlorine over the summer if you don't get it down to atleast 50.
    Re: New Here..
    We are going to be working on getting it down by draining some each month, just can't do another big drain. The pool is in Full sun all day so I read we can have a level of 80 i think.
    How much and at what level do we shock?
    Aug 2010
    Dallas, TX
    4,052
    Re: New Here..
    http://www.poolcalculator.com will help you with your levels.
    I wouldn't want to shock at a CYA level of 80...
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: New Here..
    What is your CYA level now? Have you ordered a test kit yet?
    Aug 2010
    Dallas, TX
    4,052
    Re: New Here..
    She says it's at 100. Thing is, at or over 100 it could be anything.
    When you get CYA over 100, it becomes so difficult to measure it could be 200 but reading 100.
    Re: New Here..
    I haven't ordered the test yet. The water was tested at the local pool store. It's a clear care expert computerized water analysis system.
    Re: New Here..
    The water was tested this morning
