Thread: Just set up my first intex...soft side 10 foot--Pump
    This is a rookie question.....but do you leave the pump on at all times? As in, attached to the pool? Its not ok for the electrical component to be in the rain is it? Feeling dumb.
    Mark
    -- Courtice, Ontario, Canada.
    12x16 On Ground.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Just set up my first intex...soft side 10 foot--Pump
    Welcome to tfp, kkschuessler
    I left my small intex cart filter out all summer when I had one.
    Jul 2009
    S. California
    157
    Because its such a small capacity filter, I left mine running 24 hours per day for 4 summers. It still works!
    It also was rained on, sprayed by sprinklers and splashed by kids without trouble.
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    My experience is that if the plug gets wet it will trip the built in GFCI, but getting splashed on and rained on is definitely not a problem for the pump itself.
    Summer Escapes 15'x42" AGP, Intex 14" sand filter, Intex SWG
