Results 1 to 16 of 16
Thread: still cloudy and greenish
    Jul 2012
    Northwest Alabama
    51
    i have a 14-48 ultra frame intex i been trying to clean up for a few weeks now and i am having trouble clearing it up still .....my cya was 50 and i have had it at shock level for 3 days now and it is still cloudy with a light greenish color to it ph is 7.4 and ta was 70 any suggestions on what else i need to do ordo i just need to keep it at shock level longer
    intex ultra frame 14x48 round ag, intex swg, tf100 test kit
    30,421
    Re: still cloudy and greenish
    Could you post all of your test results, please?
    Jul 2012
    Northwest Alabama
    51
    ill do all of them tonight again when i get off work and post them
    Aug 2010
    Dallas, TX
    4,052
    Going to take way more than 3 days.
    Casey's Avatar
    SW PA
    10,446
    You need to shock your pool and grab some POP.
    Jul 2012
    Northwest Alabama
    51
    pop?
    Jul 2012
    Northwest Alabama
    51
    ok i have my full test results
    fc=18
    cc=1
    tc=19
    ta=80
    cya=47
    ph=7.2 or 7.3
    still a light green cloudy and i plan on bringing chlorine levels back up a bit tonight what do yall suggest
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by chris400
    fc=18
    cc=1
    tc=19
    ta=80
    cya=47
    ph=7.2 or 7.3
    You should follow the Shock Process article in Pool School.
    pool-school/shocking_your_pool
    POP is "Pool Owner Patience"
    You're done SLAMing when:
    Jul 2012
    Northwest Alabama
    51
    clearing a little better now my fc = 28 and cc=1 ,ph,cya,and ta are all roughley same as above post.... pump running will check again tonight
    Jul 2012
    Northwest Alabama
    51
    would it be ok to go ahead and add my salt for my swg
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    I would wait. You may end up backwashing and will lose the salt you just put in!
    It is better to get the pool balanced and clear before adding salt. Got kids? Check out the highlighted post here.
    38,301
    Also, while in the shock process, you only need to be testing FC and CC ... everything else should not change and the pH test is not valid when the FC > 10ppm.
    Jul 2012
    Northwest Alabama
    51
    ok checked today about 2 hours ago and fc had dropped to 19 cc was at 1.5 (this was a 24 hour period didnt have time to check any sooner because of work) i added enough to get fc back to 25 or 27 and things are also clearing up alot more in the last 2 days....i swept the bottom and walls and sturred the dust up in it to were the filter will get it and start over again tomarrow its a little cloudy but it is now swimmable im my opinion .....ill try to post pics soon
    Richard320's Avatar
    Jan 2010
    19,009
    Movin' right along!
    Jul 2012
    Northwest Alabama
    51
    ya finally it took forever.....next year i think if it is as low of a level as it was this year ill completely drain it and scrub it and start new with new water
    Jul 2012
    Northwest Alabama
    51
    lots better ....even better than it lookd due to camera angle
