Results 1 to 15 of 15
Thread: Sand and Cartridge filter
    I have an odd question that I would welcome your thoughts on. I have for the last couple of years contemplated on adding a cartridge filter down stream of my sand filter. It should work. The sand will get 95% of the trash and the cartridge will catch 99% of what the sand misses. Assuming flow rate of the cartridge is sufficient for the the pump I see no problems in doing this. Its advantage over cartridge is that I could backwash instead of disassembling the cartridge and cleaning it. I am guessing that cleaning the cartridge at the end of the season would be sufficient due to the sand catching most of the debris pre-cartridge?
    Anyone tried it? Any thoughts on it?
    22,539
    Re: Sand and Cartridge filter
    I've thought about it but it adds head to the system and I don't think the payback would ever work out. Have you tried adding a little DE to your sand filter?
    I add ZEO Fiber D.E. substitute to my sand through the skimmer.
    Aug 2010
    Dallas, TX
    4,052
    My pool is crystal clear with just a sand filter.
    Quote Originally Posted by RobbieH
    Mine is crystal clear as well. When you get in the bottom with scuba gear on and lay there and look up you can see that the sand filter is not truly getting everything.
    22,539
    Chances are that a cartridge isn't going to get it either. You may want to consider either a small micron cartridge filter ($$$$) or a DE filter.
    I am considering D.E. in the distant future.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by reynolds357
    Stop doing that (it is likely you are the only one that is seeing anything)
    That is the best way in the world to clean the pool. You can find all kinds of stuff the robots miss.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, stop doing that!
    Essential Links:
    30,402
    Try that at night with the lights out....that should do the trick. (I'm kidding)
    At night with the lights out? That would mean I would have to break out my HID light I use for cave diving.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Take that, and shine it into one of your returns at night, then you will see the true horror.
    Essential Links:
    I will have to try that.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It will drive you crazy. I tried the slime bag here for extremely fine dust and it really has been impressive. They do work. I think the 1 micron claim is a stretch however.
    Essential Links:
