Thread: Help me figure this out
    Everything this summer has been pretty smooth until today . My water has been crystal clear with many parties and pretty much swimming everyday. I have had the IC40 cranked up to %50 while we have been having lots of groups over to swim. Yesterday was the first day we havent swam in a while. Today I took off the solar cover to a very cloudy pool. So I got out my TF100 and here are my shocking results.
    FC .5
    CC 0
    TC .5
    PH 6.7!
    TA 130!
    CYA 50
    Temp 87
    What should I do first!
    Under construction DIY 20x40 vinyl liner steel wall pool, Pentair 2hp wisperflo, Pentair tr100 sand filter, Pentair Minimax 400k heater, diving board, 8 foot sit n step, xtream waterslide, 1700 concrete deck, one amazing wife, 4 children and two German shepherds.
    38,275
    Re: Help me figure this out
    How do you have low pH with a SWG? Have you been adding a LOT of acid or have very acid tap water?
    TA is what it is, certainly not high priority.
    You need to get some FC in the water and raise the pH back into the 7s ... both are pretty high priority and can be done within an hour of each other.
    I have not added acid in a month. Our water is city water so I can't imagine it causing this, but perhaps. We have had some ash from Forrest fires, but I thought that would raise the ph?
    38,275
    Well, at this point you just have to react and keep things balanced ... although the crashing pH is quite odd.
    What were the results the previous time you tested?
