Thread: Using Plastic Zip Tie Between Titanium Plates - Is That Okay
    Miner_CLT's Avatar
    May 2013
    Charlotte, NC
    7
    Hello Fellow SWG Owners,
    I have an Intex SWG and I have to clean the titanium plates every 4-5 days. I soak the plates in vinegar as recommended, but it does not get all the calcium deposits out between the plates. Since the manual says you can clean them with plastic, I used a plastic zip-tie to push out the stuck pieces. Is that okay?
    Also, why am I having to clean them so often?
    Current Levels:
    Gallons of Water = 8500
    FC = 4
    Ph = 7.5
    TA = 130
    CH = 250
    CYA = 50
    SALT = 3200
    Temp = 84 (f)
    Phosphates = 0
    Any responses are sincerely appreciated.
    Kind regards,
    Miner in Charlotte
    Intex 12X24X52 Ultra Frame Rectangular Pool
    Intex Saltwater System
    Intex 14" Sand Filter[/color]
    8500 Gallons
    38,262
    Re: Using Plastic Zip Tie Between Titanium Plates - Is That
    Given those test results, there is nothing indicating that you would be getting a lot of calcium buildup. But if your pH every gets > 7.8 then you are becoming at risk.
    Lowering your TA could reduce how quickly the pH rises and make even 7.8 fine on the CSI index.
    Nothing wrong with using a zip tie ... Another option would be something like a popsicle stick.
    Miner_CLT's Avatar
    May 2013
    Charlotte, NC
    7
    Thanks Jason! I never thought of a popsicle stick...good idea!! Instruction manual for SWG calls for TA at optimum level of 130; pH does rise ever so often; and it may take me a day or two to catch it; which might explain my problem.
    Thanks again!
    Miner in Charlotte
    8500 Gallons
    38,262
    If you have not already, check out the recommended levels in Pool School ... our recommendations generally do not agree with other sources.
    pool-school/recommended_levels
    pool-school/water_balance_saltwater_generator
    I have been cleaning mine with a diluted MA mixture (1 part MA to 4 parts water) and it's faster and more effective than vinegar... you can also just soak longer and it will eventually dissolve the crud in between.
    Summer Escapes 15'x42" AGP, Intex 14" sand filter, Intex SWG
    Miner_CLT's Avatar
    May 2013
    Charlotte, NC
    7
    Thank you! Another good idea!
    Miner in Charlotte
    8500 Gallons
