Thread: how long are reagents good for?
    Using TF100 test kit from last year i was getting CYA reading of around 40, when i ran out of reagents i had my water tested at Leslie's and got a CYA reading of 30. I ordered new reagents for the test kit and the first test with the reagents was CYA of 65.
    All readings were within 5 days.
    Should i assume 65 is the right number?
    Did no draining of pool or added any cherms other than bleach.
    38,475
    Re: how long are reagents good for?
    The CYA reagents are inert, so should last a long time ... in fact most of the reagents "should" last a couple years if they are stored in a cool dark place.
    {I have a 3 year old TF100, where all the tests still give basically the same results as my 3 month old TF100}
    22,553
    Yes, you should assume that it's whatever you tested it at.
    Forget the pool store result, was the lighting the same during both of your tests? Did you test in indirect sunlight..?
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
