Results 1 to 7 of 7
Thread: Ye Ole Acid Demand
    Ye Ole Acid Demand
    22000 Gallons
    Grey Plaster (Calcified pretty bad)
    FC 3.0
    CC 0
    TA 60
    PH 7.2
    CH 160
    CYA Less than 30 (Taylor kit doesn't go that low) Guessing it's at 10 or so
    Borates 50
    BBB Method here but using pucks to bring CYA up to 30-50 range
    Currently to keep Ph at 7.2-7.4 range I am consuming 1 Quart of 15% MA per day. It's starting to add up...... This is even with a floater full of pucks... I use around 2 gal of 8% Bleach weekly as well.
    Any thoughts on MA demand reduction?
    Does the fact that I'm riding the CSI close to the edge have any effect?
    Thx
    Re: Ye Ole Acid Demand
    You are trying to keep the PH quite low, which is at least most of why the PH tends to go up, and also why your CSI is low. We recommend keeping PH between 7.5 and 7.8.
    I was trying to keep the CSI the lowest it could be without exceeding -0.6 to descale a bit. I've been riding at -0.59 with the PH at 7.3
    Calcite Saturation Index - requires pH, TA, CH, CYA, Temp, uses Borate, Salt
    Less than -0.6 is suggestive of problems for plaster, tile, stone, and pebble pools.
    Greater than 0.6 is suggestive of problems for all pools.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Quote Originally Posted by poolvibe
    If you're purposely trying to descale, then you WILL use a lot of acid. Your CH should also be climbing.
    Yea Richard.... I kinda suspected I might be acid poor soon LOL.
    If I am looking at a CSI of -0.59 vs say something like -0.35, am I going to see a radical difference or am I looking at more of a long term difference (in years) I just want to make sure I am consistently pulling calcium off the plaster.
    Richard320's Avatar
    Jan 2010
    18,966
    It's going to take years. progress-on-scale-t38568.html
    Jun 2011
    Long Beach, CA
    2,778
    I have found that the places around me charge about the same amount for the 15% or 31% acid. You might only need to add half as much acid, and pay half as much as you have been paying for the full strength acid.
