Thread: Want to Order 1-1/2 LB Check Valve for Ozone
    Anyone know where I can order a check valve for my ozone line?
    1/2 male threads into pump
    3/8 air line compression fitting
    1.5 LB check
    I've spent quite some time searching the internet but can't find much.
    Brian
    [attachment=0:12s7uhal]checkvalve.JPG[/attachment:12s7uhal]
    13'000 gal - cartridge - IG - plaster - UltraPure ozone
    38,284
    Re: Want to Order 1-1/2 LB Check Valve for Ozone
    We have VERY few members here that use Ozone, so I am not sure if you will get much response.
    For outdoor pools, chlorine is sufficient in and of itself, therefore there is no need for ozone or UV systems. They are just an added expense with little if any practical benefit.
    Aug 2010
    9
    Hi Zazoh,
    I'm not sure if you have purchased a replacement check valve yet, but if you'd like to contact me I can send you to the right place to get one.
    Brian Richardson
