Results 1 to 13 of 13
Thread: Stabilizer granules from Walmart - how to dispense in pool?
    Jul 2010
    Raleigh, NC
    60
    Pool should be full by tonight & hope to start the pump & filter for the 1st time. I went ahead & bought some of the stabilizer granules from Walmart. What's the best way to add these to the pool?
    26' x 52" Intex Ultra Frame (14,667 gallons), Hayward Matrix 1hp 2speed, Hayward ProSeries 21" sand filter
    1.5" PVC piping with in-wall skimmer, TF100 test kit
    City water in Raleigh, NC
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    470
    Re: Stabilizer granules from Walmart - how to dispense in po
    I got some of those too. The instructions say to slowly pour them in the skimmer, and that's what I did. I'm a newbie though, maybe there is a better way.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    May 2013
    Bay City, Michigan
    283
    In a sock of some sort, hanging in front of a return jet. Also helps to give it a squeeze once in a while. If not practical, can put in sock in skimmer, but can't backwash for a week or so.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    22,550
    The sock full of it in front of a running return is the best way. Just give it a squeeze whenever you are near it.
    Jul 2010
    Raleigh, NC
    60
    I don't have a skimmer so "sock in front of the return" it will be ....
    By "sock" do you mean a pantyhose stocking, a true cotton sock, or some other type?
    I'll start adding it tonight so it will likely be unattended most of the night (no good squeezes) .. will this matter?
    Also, can we swim while this is being added or must be stay out of the pool?
    Sorry for just elementary questions ... just want to get it right the first time.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Doesn't matter that you can't squeeze it tonight!! Squeezing it is only a help, not a requirement. And yes, you can swim while adding it. Have the swimmers give it a squeeze every now and then.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jul 2010
    Raleigh, NC
    60
    Exactly what I needed to know! Thanks for all the replies, and thanks Richard for the pictures.
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    If you poured it in the skimmer keep your pump running for atleast 24 hours.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Jul 2011
    844
    And don't backwash!!
    Bestway SWG
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I put mine in the skimmer, never had a problem.
    Casey's Avatar
    SW PA
    10,444
    Quote Originally Posted by Richard320
    OMG! This is the best pic for adding CYA! I almost fell out of my chair laughing!
    Jul 2011
    844
    Quote Originally Posted by cramar
    That's perfectly fine. My advice about backwashing was to make sure he didn't backwash before the granules were dissolved or he'd lose the undissolved CYA. Sorry I should have made that clearer.
    GC
    Bestway SWG
