Results 1 to 10 of 10
Thread: Intex SF15110 Pump
    Jul 2012
    Holden Beach, NC
    9
    Intex SF15110 Pump
    I have had my pool since last summer (june 2012). Intex has replaced two SW generators (which each died after 2 weeks) and now my pump has quit. The motor just hums when turned on as if something is stuck in the impeller. Anyone with ideas, suggestions, or who has experienced same problems and found a solution, please reply.
    Intex Ultra Frame 24' x 12' x 52"
    1600 GPH 1/2 hp pump w/14" sand filter
    Intex 8100 series chlorine generator
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex SF15110 Pump
    Have you checked the impeller for blockage? Make sure the pump is off when you do this. Also, I am not sure about the intex motors, but with most pool pump moters you can remove the back cover and turn the motor shaft to free it up.
    Jul 2012
    Holden Beach, NC
    9
    I have checked the impeller. It seems to be the capacitor. Motor will turn with assistance on start up, but will not start on it own, only hums. And as with all intex stuff, I am having a very hard time finding a capacitor with same specs.
    ANy ideas?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yeah, they can be tricky to find. Here is an old thread about the intex 2500 cart filter capacitor replacement: http://www.troublefreepool.com/intex...ly-t30728.html Maybe that will help. Do you have the capacitor model number?
    Jul 2012
    Holden Beach, NC
    9
    capacitor is cbb 61. 16uf, 250vac. thanks for the link
    Jul 2012
    Holden Beach, NC
    9
    Just ordered the "Amico AC 450V 16uF Motor Start Aluminum Electrolytic Capacitor" from amazon for 8 bucks. had good reviews, even though made overseas. hope it works. will update post on thursday when it arrives.
    Jul 2012
    Holden Beach, NC
    9
    thanks for all your help linen.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    you bet...though you did all the work Let us know how it turns out.
    Jul 2012
    Holden Beach, NC
    9
    Intex actually replaced the pump under warranty. I had to find my original purchase receipt, but no other hassel then that. IT was 365 days to the day when the pump quit, so i can say they actually honor their 1 year warranty. All is working well for now.
    As far as the capacitor, I replaced it, old pump ran about 1 hour, creating new noises as it did. I figured it had to be more then the capacitor.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Thanks for the update, sounds like intex did a stand up job!
