Thread: Safe to Swim / cloudy
    Good day all,
    My pool is almost crystal clear. Still a little cloudy with goggles on but the deep end is visible from up above.
    Cholrine is a little high but we've had a lot of rain lately.
    I've also been using DE to help with the cloudiness but we are on week 2 of the clean and still cloudy.
    TC 15
    CYA 60
    TA 90
    PH 7.2
    CA 230
    Is it ok to swim when its cloudy? And will I ever win this battle?
    please help.
    thank you
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Safe to Swim / cloudy
    Can you see the drain from the deck?
    Is the water greenish, or just white/grey?
    What is the CC level?
    Quote Originally Posted by Richard320
    Yes I can see the drain from the deck. Its looks great from above. White cloudy.
    What is CC stand for again sorry brain not functioning
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    CC= combined chlorine
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
    30,432
    Go swimming! Boost your FC back up to 24 tonight and keep the pump running 24/7....your pool will clear.
    Thank you!
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
