Results 1 to 9 of 9
Thread: Shocking: Why bleach and not chlorine sticks
    It may be here somewhere, but can someone explain why it is best to use bleach instead of chlorine tabs to shock or increase FC in a SWG pool? How much bleach and what kind? In understand the SWG's role in slowly raising or maintaining FC, but how does bleach work over chlorine tabs when one needs to shock, due to algae, etc.?
    22,550
    Re: Shocking: Why bleach and not chlorine sticks
    CYA! Tabs add it, bleach doesn't.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Speed to raise and the ability to HOLD shock level without any other additives you don't need....calcium, cya. Plain simple odorless bleach.
    Apr 2013
    Central Massachusetts
    174
    Tabs and sticks take time to dissolve and they also contain CYA. To shock you want to bring up your FC immediately and most the time you want to avoid adding CYA. Simple liquid bleach/chlorine is the best (but can be a pain to transport compared to the other options).
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    Chlorine tablets/sticks are generally made out of trichlor. Trichlor adds chlorine (good), CYA (usually bad), and lowers PH (often annoying). They also dissolve too slowly to be used when shocking.
    Bleach/liquid chlorine "dissolves" instantly, since it is already a liquid, and doesn't add anything that you don't want to the pool. It is also one of the least expensive forms of chlorine.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Bleach is chlorine, just in liquid form without the additives that chlorine tabs have in them. Chlorine tabs require either CYA or Calcium to bind with the chlorine. We advocate using bleach/liquid chlorine because it only adds Chlorine to the water. If you use the tabs you are constantly adding CYA or Calcium, which builds up over time in your pool leading eventually to water replacement.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    The solid forms of chlorine add either cyanuric acid, calcium, or lithium to the water.
    High CYA renders FC ineffective and algae can flourish. If you've read any of the green pool threads, you'll find that most begin with high CYA levels. Dichlor and Trichlor also lower pH tremendously. Calcium buildup leads to scaling. The Lithium stuff is mega expensive. And before you ask - it's not possible to make a stable solid chlorine compound without these unwanted byproducts. If someone could, they'd be a billionaire.
    [center:2gcgsk2m]
    [/center:2gcgsk2m]
    Thanks! Use something like http://poolcalculator.com/ to calculate how much to add and just use regular grocery store bleach?
    Aug 2010
    Dallas, TX
    4,052
    yes.
