Results 1 to 10 of 10
Thread: BBB Believer, Using Pucks for the first time
    May 2012
    Flower Mound, TX
    130
    Let me first start by saying, I have been using Bleach to chlorine my pool since start up since March 2013. Having great results.
    FC: 3 - 5
    CC: 0
    PH: 7.6
    TA: 70
    CH: 260
    CYA: 35
    CSI: 0 - .03
    POOL TEMP: avg.88
    AIR TEMP: avg.95
    My PB left me with a bucket of Chlorine Pucks (never used them), Since my CYA is close to the low side I thought I would try it. Well, I start using the pucks yesterday (sat.).
    My pump runs for 8 hrs a day 1100 - 1900, 5hrs low speed 1100-1600, 3hrs high speed 1600-1900.
    SATURDAY
    1630 - FC: 2.5 CYA: 35
    1700 - installed 7 pucks in cylinder, turn dial to setting #4
    SUNDAY
    1300 - FC: 1.5, turn dial to setting #4.5 (pump running on low speed)
    1600 - FC: 1.5 (pump just started on high speed)
    1900 - FC: 2.0, turn dial to max setting #5 (pump finished on high speed)
    Since pump shuts off at 1900, no since checking FC after 1900 when pump is not running.
    Will check tomorrow on FC results, and check this weekend for CYA level. The pucks doesn't look like its going to keep my FC high enough for my likings And I wonder what my CYA level going to be this weekend? I check FC/PH everyday, and check CC/TA/CH/CYA every weekend.
    Anyone having good luck with FC & CYA using the pucks, or should I sale them in a garage sale?
    Thanks, John
    14,000 gallon IG DiamondBrite pool with 2 ea. waterfalls and slide, Hayward Tristar 2.0 HP 2-speed pump, Hayward 3/4 HP waterfeature booster pump, Hayward 48sf DE filter, Hayward PS4 wireless controller, 1 skimmer and 4 returns, Polaris 280 pressure cleaner w/booster pump, 7 x 7 spa w/6 jets, TF-100 Test Kit w/speed stir
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: BBB Believer, Using Pucks for the first time
    Those pucks are always useful for vacations and weekends away during pool season.
    How many would you recommend adding if you were going away for a weekend? We have a SWG.
    Thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by Lizt111
    Thanks!
    If you have a SWG you don't need pucks or chlorine. Well, maybe keep a couple jugs of bleach around for a boost if you have a party or something.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I had some leftover pucks and used them to raise my CYA instead of buying stabilizer.
    chiefwej
    May 2013
    Bay City, Michigan
    283
    Quote Originally Posted by JohnH
    Wow did you buy gallon size container of the CYA reagent?
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Quote Originally Posted by Richard320
    Thanks!
    Thanks! I thought I might need to add the pucks if we were going to be gone for 2-3 days.
    Aug 2010
    Dallas, TX
    4,052
    The whole reason I have an SWG is so that I NEVER (pretty much) have to WORRY about FC. I just got home from being gone 4 weeks on the road. pH was high, but FC was perfect.
    May 2012
    Flower Mound, TX
    130
    Quote Originally Posted by scott.MI
    I'm still using what I have from the TF-100 kit, 15ml pool water mixed with 15ml cya agent.
    May 2012
    Flower Mound, TX
    130
    well, its 1800 Monday evening, time to check FC & PH. FC: 1.5 / PH: 7.7. PUCKS SUCKS
    I'm not getting my FC Target of 5 (for CYA 35), I'm not even getting my minimum target of 3 with the pucks.
    I had to go to my bleach and add 74 oz. to meet my target of 5. I'm sure the In-line feeder is working, or I wouldn't even get a reading of 1.5. It has water and the dial is at max. setting at 5.
    I just wanted to check out the puck system since we will be gone 5 days during the 4th. I'm not impressed at all with that system.(automatic chlorine in-line feeder)
    Any Thoughts?
    John
