Thread: de in pool when vacuuming to waste after replacing grids
    hi,
    entire filter replaced last year, de stays in fliter when multiport is set to filter. when multiport set to waste, de flows into return lines. Pool company said grids need to be replaced, made repair, same result. then pool company said manifold needed to be replaced, made repair, same result.
    it seems unbelievable to me that the pool company doesn't test after repair. Anyhow, any ideas would be appreciated.
    37x20, 28,300 gallon gunite, irregularly shaped, hayward 1.5 super pump, hayward 4820 DE filter, northeast geo
    Re: de in pool when vacuuming to waste after replacing grids
    That sounds like a problem with the multi-port valve. If it was a problem with the filter you would get DE in the pool even when filtering.
    thank you so much for your reply! this started me thinking that the pool company was not communicating the problem to the pool techs. I called this morning and asked them what they thought was the problem:
    "de in your pool when turning on the filter". So they were testing, but they didn't understand the problem. On the phone, they came to the same conclusion, a multiport problem and they're coming out today to fix.
    thanks again!
