Results 1 to 10 of 10
Thread: Measuring strength of bleach - tool questions.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I'm about to embark on the adventure of verifying bleach strength by measuring it using Chem Geek's posted method, or Jason Lion, both have posted it.
    Bleach strength testing procedure.
    I know I need @ least 2 - 1ml pipettes, since the initial measure of undilute bleach will leave residue behind that'll taint the 2nd - 1ml measure in the process.
    Some of these questions are going to seem, well... newbish. Seeing as I know nothing about lab equipment... please bear with me.
    I know from wetchem's post here: graduated-cylinder-incorrect-or-am-i-doing-it-wrong-t48136.html#p392611
    That I DO NOT want the "eye dropper" style pipettes. Very inaccurate!
    So I have been poking around Amazon, trying to figure out what to buy. I see the ones that wetchem linked to for pretty cheap on Amazon. But they're disposable & I have read the little colored strip inside can come loose and float around in your liquid being measured.
    Is this really a problem, or was it a typical "lacking internet review"?
    I'd prefer a glass, non-disposable pipette, or at least a more durable non-disposable plastic type.
    I'm thinking 2 of these: Mohr Glass Pipets, Class B, 1ml
    Or maybe these: 25 KIMBLE 1ml x1/100 Serological Pipets Plugged Sterile Glass
    Or lastly, a few of these: Pyrex Glass Pipettes, disposable ::: 1ml in 1/100ml
    They're all pretty close in price, about $10-12 for 2 or more of them. Is any one better suited than the other, or would hold up better for multiple uses, or no?
    How do I get the liquid to be measured into & out of it, is a syringe sufficient, or do I need a pipette pump like this? Pipette Pump 2ml
    I'd like to avoid the extra bones for the pump, trying to do this on the cheap, but if it results in massive frustration otherwise, then I wouldn't be opposed to it.
    If I use a pipette pump, so as not to contaminate the second sample with high concentration bleach residue, do I need 2 of them? Or does the liquid not enter into the pump?
    I ask about getting it out because I don't know if surface tension is going to be a problem for releasing it. IE. Unable to easily pour it out.
    Does the liquid enter the pipette only from the top and the pointed end is sealed, or is the pointed end an opening and is sort of like a one way valve due to high surface tension?
    I see some of them sold as "plugged".
    As for the 100ml mixing & containment, do I really need beakers, or can I get away with these that I already have? They both have mL markings and hold 100ml /w plenty of extra room. They're both Anchor Hocking & they're new. I wash them by hand so the numbers don't come off. So far, so good.
    [attachment=1:2te0btio]5ozMeasureGlass_Main.jpg[/attachment:2te0btio] [attachment=0:2te0btio]1cup_anchor_measure.jpg[/attachment:2te0btio]
    Are they accurate enough for these purposes, or do I need more precision since working with such a high dilution ratio in such a small volume?
    Would the following be a must for what I'm doing, or does it not matter since it's not high end labware, so the accuracy is... meh?
    Glass Beaker Set - 3 Sizes - 50, 100 and 250ml, Karter Scientific 214T2
    Thanks!
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Re: Measuring strength of bleach - tool questions.
    Taylor has a bleach test kit that might suit your purposes.
    http://www.taylortechnologies.com/produ ... KitID=2191
    Support the site
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Yeah I know, I really don't want to spend that kind of money just to make sure I'm getting what I pay for. Defeats the purpose, ya know?
    It's like a $70+ kit!!
    If I lived in pool country, I wouldn't even really care. But things sit on the shelf here, longer than they should. Pricing is high too. So finding the best deal is hard.
    Thanks though.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    No tips on which pippettes or how to use them?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The Pipettes you show on amazon need a pump or bulb to draw in the liquid. Since you are out to save money, I would suggest finding a syringe. Much cheaper, much easier and way more durable than a Pipette. I can send you a few (no needles) if you want. PM Me if you can't round some up.
    Essential Links:
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I wouldn't be opposed to buying a pipette pump, if that cheap one I linked to would work. Does it actually draw it into the pump, or no?
    Would a syringe be accurate enough?
    Any idea if those anchor hocking things are accurate enough?
    Jun 2013
    Central Illinois
    13
    you might check at a farm store. They usually have 1 cc (same as mL) syringes with or without needles for less than a buck. Also 3 cc (same as 3mL).
    8K Gal, Intex 20' X 48" Ultra Frame Round Pool (PVC Liner), Cartridge Filter
    First pool setup 6/17/13
    I am both a newbie and a cheapskate. Please forgive my stubbornness and ignorance.
    Mental Note: Shocking the Pool does not involve an electric cord...
    If you know the volume of your pool and measure chlorine before and after adding a know amount you can figure it out without buying any extra equipment. Another plus of this method is you are working with larger volumes so small variations in measuring are insignificant.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by y_not
    Yes, the pumps pull it in and hold it. You typically over draw, then purge to the amount you want. Syringes are extremely precise...think about it, they dispense medicine into a body. They have to be dead on for that. The measuring cups are fine too, especially for what we want them for. Certified lab grade accurate, no.
    Essential Links:
    The liquid should not be drawn into the pump. The pump is attached to one end of a serological pipette to create a vacuum that draws liquid into the pipette. The "plugged" pipettes have some sort of fiber (looks like cotton) on the end near the pump to help prevent vapor from the liquid from being drawn into the pump.
    As others have mentioned, syringes would be a less expensive, equally accurate solution.
