Thread: AG air between wall and liner...
    hello,
    i live in north alabama, and my wife and i have just put up a 24 x 52 AG, with an overlap liner.
    we tried to vacuum the air out through the return after the skimmer was installed but the vinyl just closed up on the vacuum hose.
    now we have a "bubble" of air nearly all the way around the pool between the liner and the wall, above the water line. we also have
    wrinkles in about half of this same area.
    i took off a retaining ring and a couple of coping strips and tried again to vacuum the excess air out but still no luck. the pool is
    90% full and i can't afford to drain it.
    any suggestions on how to correct this problem are much appreciated!
    (i wish i'd payed to have the liner installed...oh well)
    thanks-
    22,553
    Re: AG air between wall and liner...
    Don't worry about it. It's not hurting anything to be there and it will dissipate over time.
    Thanks... That's exactly the advice I was looking for
