Results 1 to 7 of 7
Thread: store chemicals and k-2006 in shed?
    Jun 2013
    Newcastle, Oklahoma
    508
    so im having a brand new 10x10 wood shed w/ composite roof brought in next week that will be put down about 15-20 feet from pool for lawn equipment, riding tractor, etc. my pool is a ways away from house. i currently keep bleach on back porch in shade. k-2006 kit, borax and soda in wash room cabinet in house.
    it sure would be nice to not have to walk back up to house several times a morning when doing my testing and chem adding. i have some nice metal shelving that i plan to put in building for chemicals and what not...
    im sure bleach would be fine in shed (as said its on back porch now)
    but what about borax and soda?
    and most importantly my k-2006 test kit? no where does it say a storage temp. at 95-100 degress in oklahoma mid summer, it would be about 85ish probably in shed.
    would my chems and kit be okay to store out there?
    thanks!
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: store chemicals and k-2006 in shed?
    I keep my chemicals in a shed year-round. The test kit stays indoors and I just bring it out with me when it's test time.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    If you go through your chemicals fast you won't have a problem. Bleach is the one most susceptible to heat and light. If you use it quickly, it won't have time to go bad.
    As far as test kit goes I would NOT leave it not shed. You will drastically shorten the shelf life of the reagents and possibly affect your test results.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Quote Originally Posted by gtnos
    I'd bet you it would get hotter than that in there. Also the temp swings are bad too. See link below.
    Storage of your Taylor Test Kit
    Jun 2013
    Newcastle, Oklahoma
    508
    thanks guys. chemicals in the shed, test kit will stay in laundry room. i dont stock bleach more than a month supply if even that, so i shouldnt have any issues with it going bad in heat.
    Butterfly's Avatar
    South Carolina
    10,045
    Make sure to keep MA and chlorine sources SEPARATED. They do not play well together.
    You can set the MA jug in a 5 gal. bucket JIC it should leak.
    You're done SLAMing when:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Butterfly
    Beat me to it. I always like throwing that in. Bleach and acid mixing is bad, bad, bad!
    Essential Links:
