Results 1 to 14 of 14
Thread: Green bullet
    Green bullet
    I am buying a short sale that has a pool that has not had any maintenance for the past 2 years at least. I hired a pool inspector, received an estimate of ~ 11,000.00 to get everything up and running. I definitely can leave off the pool heater for 3200.00. I have some other priorities than the pool. Can anyone give me advice on a product called "green bullet"?
    22,551
    Re: Green bullet
    Never heard anything about it. Do you know anything about it?
    What all did they say was wrong with the pool?
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Re: Green bullet
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Green bullet
    I'd be more interested in what they think costs $11K rather than a product that you put in the pool.
    Do you think the $11K is reasonable? Based on what? Just asking questions.
    Welcome to the forum
    You're done SLAMing when:
    Apr 2009
    South Texas
    177
    Re: Green bullet
    $75 per gallon??? And it's not even completely clean in their video. I couldn't find the ingredients so that's scary. Get one of the recommended test kits and stick with plain bleach and the shock process outlined in pool school. You'll save a fortune!!!
    Just bought a new house in the country, no pool yet. :(
    Hot tub..500 gals..bromine
    TF100 test kit and speedstir
    Re: Green bullet
    After reading more throughout your forum I am definitely going to follow your advice. My estimate consisted of 500-800. Replace leaking cracked plumbing. Rebuild a 48sq ft PAC Fab DE filter, grid assembly, O rings and inside ss filter - 600. Clean leaves off cover, drain, pressure and acid wash - 1200.00, replaster and repair leaks $6000.00. A 336,000 BTU heater installed - 3200.00, which i don't quite understand because he said the spa heater is working. After everything, bring chemicals and teach me how to care for the pool- 500.,. This gentleman came out and redid the pool 12 years ago.
    22,551
    Re: Green bullet
    You should take some time and tackle it yourself. Don't replace anything that doesn't need it.
    Re: Green bullet
    The pool seems to be holding water fine. Of course until I close, I can't get to anything. It could be the muck holding it together. Any suggestions for getting the 3 inches if muck off the liner and secondly is it impair able I drain it immediately?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Green bullet
    Can you get a few pics of the pool and post them here?
    Order the test kit!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Green bullet
    Quote Originally Posted by dattia
    http://thegreenbullet.com/
    Based on their Foreclosed Pool Abatement page, it sounds like they are removing one of "abundant food, light and water" and since they aren't removing light and water that means they are removing "abundant food". Most likely it's just lanthanum chloride (or lanthanum carbonate) and therefore is a phosphate remover. That's why it takes time to kill the algae since there is nothing actually killing them so you have to wait 2 days for them to essentially "starve". Note that they also say "When the the Green Bullet begins to inject into the pool slowly move the nozzle back and forth to distribute the product throughout the pool. An immediate cloudiness will occur." That also implies a phosphate remover. They also say under their Ponds with Aquatic Life page that "The Green Bullet actually is a vehicle for the algae as it carries the algae to the filter and re-liquefies at that point and goes back into the body of water to work again to grab more particulate and bring it to the filter." So it probably also has a clarifier in it as well except that usually a clarifier gets caught in the filter and doesn't go back into the water to get more algae. On the Fountains and Water Features page they say "The Green Bullet is not a gas but rather a proprietary blend of polymeric salts." Here again this sounds like a combination of a clarifier (polymer) and phosphate remover (salts).
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Green bullet
    Quote Originally Posted by cherokeerose
    Liner? or plaster....
    I've done foreclosure pools a few times - How can they know it needs acid wash/plaster repair if the cover is still on?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Green bullet
    Can you say "Inflate the cost as much as possible"? Unless they have knowledge of the pool condition they aren't divulging. Not an outright lie, but not telling the full story.
    Jan 2013
    Houston, TX
    1,079
    Re: Green bullet
    suspicious.... Close then turn it all on.
    I got an $8900 estimate for a pool that didnt actually need anything (thanks to TFP I knew it before hand but had to get the inspection for home warranty purposes).
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Re: Green bullet
    The pool is gunite. I think the construction date is 1978, but it was re-plastered 12 years ago. As I mentioned, it has sat covered and unused for the last 2 years.
    I'll try to attach 2 pix of the swamp with the cover on.
