Thread: best time to test / add chemicals?
    Jun 2013
    Newcastle, Oklahoma
    508
    well, other than that little mishap the other day with the new sandfilter shooting sand in my pool ive had 0 problems with my pool. here is my latest results as of 9 am today
    pH - 7.6 (ranges from 7.6-7.8 daily without me doing anything)
    FC - 3.5 (adding ~50 - 55oz of 8% daily to keep running pool around 9)
    CC - zero every morning
    CYA - 90 ( a little high i know, but pool is in full sun all day, and i plan on draining a bit in a week or so to put in hayward skimmer, so that will come down some when i refill)
    CH - 70
    TA - 100
    i get up and test this pool every morning religously about 830-900 am with my K-2006 kit for FC, CC, and pH. i test every sunday for TA. today was first CH test. my pump runs 6 hours coming on at 8. i test, and add chemicals for the day.
    pool is crystal clear.
    do you guys test / add chem in morning or evening? or does it matter?
    also, my TA has held solid 100 for near two weeks. thinking if it is 100 next sunday, i may start testing it every other week rather than weekly.
    ill probably do CH test monthly
    i realize what im doing is working, just curious.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: best time to test / add chemicals?
    Everything you're doing sounds fine. Some people dose the bleach in the evening to delay breakdown in the sun until the next morning, but with a clean pool, it really doesn't matter.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Personally, I test twice a day (I'm a bit OCD about the pool), and dose as needed in the evenings. Skimming, then brushing/vacuuming as needed in the AM.
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    once I get zeroed in I just test my CL daily.. and do a full test on the weekend.. my pool seems to take 1.5Ltrs of 12% CL every night. I leave for work at 5:30'ish every day so no time to do pool stuff in the AM.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
