Results 1 to 7 of 7
Thread: muriatic acid
    delfargo's Avatar
    May 2008
    some cornfield in central illinois
    86
    muriatic acid
    hey pool gurus....just got a quick question. this is the first year i'm using the b-b-b method and it's working great. the pool has never looked this good so soon after opening. as this is my first year, i've never dealt with muriatic acid before. i was wondering if it is normal to see a cloud of fumes coming out of the jug. just curious. thanx.
    30' round above ground - 21000 gal. (shade ONLY in the evening),
    pentair dynamo 1.5 hp pump,
    pentair sand dollar 150 lb.sand filter,
    bbb method.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Yes, it is normal. I hold my breath while the jug is open. Nasty stuff if you get a whiff.
    delfargo's Avatar
    May 2008
    86
    thanx john. i thought maybe i was storing it wrong or something. glad to hear it's normal. and by the way, i did accidently get a quick whiff, and i won't be doing that again. wow! nasty stuff indeed!
    bbb method.
    Jul 2007
    Sahuarita, AZ
    278
    I keep reading about this, but I've been using MA for a year now and have yet to see or notice these fumes. I only can get the 15% stuff in my nearby store though... guess it doesn't vaporize as easily.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    Guest
    Quote Originally Posted by EskimoPie
    Exactly.
    Fayetteville, Arkansas
    220
    Quote Originally Posted by JohnT
    You dang right it's nasty stuff!! I got a good whiff last season, so I only use the dry now.
    20x40 30,000 gal IG Liner, Pentair II Sand
    Muriatic acid is standardized generally to 31.45%. I always see noticeable fumes. I did get a whiff of it once and regretted that. Now I hold my breath when I work with it (I should really have known better, as I've used HCl a lot in the lab, but I work under a fume hood there). I dilute mine in water before adding it to the pool or spa, as it's a bit easier on the pool liner, and I never see fumes after that. (Remember, if you do this, always add the acid to the water, not the water to the acid.)
    It's fun to add to a bromine spa as it briefly will produce liquid bromine (dark brown) which quickly disappears back into the water. (Don't do this indoors...)
