Thread: CYA zero
    Jun 2013
    kouts indiana
    9
    CYA zero
    Hello new here but not to pools. How ever this is the first year I have really had problems. The pool was not covered this year and went soup green with leaves and a lot of tad poles were in the pool. I have it to a real cloudy look with all alegy at the bottom I believe. The ph is adjusted to about 7.8 the TA is a little above 80 the TH and CYA will not register on the test strips. (after reading here i will buy a better test kit soon but have to work with this now.) put 8 gallons of bleach in this weekend and still nothing in the pool. Help please.
    1600 gal AG Oval
    18x34
    1 1/2 HP hay 4 lb de 38 GPM
    Roover vac.
    pool owner 19 years
    30,402
    Re: CYA zero
    read "The ABC's of Pool Water Chemistry" up in Pool School to understand the function of CYA and why you need it.
    Then, read "How to Shock Your Pool" up in Pool School. You will have a VERY difficult time performing that process with strips but that's what you need to do.
    Jun 2013
    kouts indiana
    9
    Re: CYA zero
    well I added 4 lbs of stabilizer i will see what happens. I am usually the first one to have pool open this year I will be the last. UGH!!!!!!
    1600 gal AG Oval
    18x34
    Roover vac.
    pool owner 19 years
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: CYA zero
    Quote Originally Posted by jim001
    But if you get one of the recommended test kits and follow Pool School, you'll have the clearest sparkliest water in the neighborhood.
