Results 1 to 9 of 9
Thread: Bleach
    May 2008
    S.C.Myrtle Beach
    47
    Bleach
    Am i right? Is everyone useing bleach instead of chlorine tablets for your CC & FC ?
    Carolina Girl!
    Pentair 1 1/2 Hp
    Pentair clean & Clear Cartridge filter
    14 x 32 FG inground Pool
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Yes.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Bleach
    Quote Originally Posted by hairco
    To maintain my FC or to schock (get rid of CC), I use plain, unscented 6% bleach.
    Sometimes I use the tabs (because I already have a bucket full) if I need to raise my CYA level or for vacation.
    You're done SLAMing when:
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Yes. I've used pucks while vacationing, but bleach is all I ever use for chlorination.
    Mar 2007
    San Rafael, CA USA
    12,082
    I use 12.5% chlorinating liquid from my pool store where they reuse the bottles (so no waste or recycling needed). I only use stabilized chlorine to increase my pool's CYA level, typically at the start of a swim season.
    Guest
    Plain, unscented laundry bleach and liquid pool chlorine are one and the same except for the strength. Both are sdoium hypochlorite. There are several kinds of chloirine that are suitable for a pool but they fall into two major groups, stabilized and unstabilzied.
    The Stabilized chlorines are trichlor tablets and dichlor granules (which is sometimes sold as 'shock'). Both of these will cause your CYA (stabilizer) levels to rise as you use them and eventually lead to an over stabilized pool with all the problems that brings. With a cartridge filter this will happen in just a few months. It will take a bit longer with a sand or DE filter that is cleaned by backwashing bit it will still happen in most cases. The reason that many people use trichlor tablets in a feeder or floater is because trichlor is a very slow dissolving form of chlorine and it is the only form of chlorine that works with a feeder or floater. It's a esy way to chlrinate a pool until the stabilzier becomes too high.
    The unstabilized chlorines are sodium hypochlorite (bleach and liquid pool chlorine), calcium hypochlorite (usually sold as powdered 'shock' but also sold as chlorinating granules) amd lithium hypochlorite (also sold as 'shock'). They do not contain CYA so they will not cause overstabilization.
    Calcium Hypochlorite (cal hypo) wil cause your calcium levels to rise since it adds calcium to the water. This might or might not be a problem. It depends on how high your calcium levels are in your pool and fill water.
    Lithium hypochlorite's only disadvatage is that is it the most expensive form of chlorine you can buy. If you can afford it go for it! It has no major side effects and it is convenient because it's a fast dissolving granule.
    Sodium hypochlorite (bleach) also has no major disadvantages and is a very economical form of chlorine, which is why it is the one we recommend.
    When using unstabilized chlorine in any of it's forms you do need to add chlorine to the pool daily but we are talking about 5 munites worth of daily testing and maintenance so it's not that much work and the rewards are a trouble free pool.
    Hope this info is useful.
    May 2008
    S.C.Myrtle Beach
    47
    I had to put acid in my pool so now i don't have any CC FC So i thought i would try blesch .
    Is that ok?
    Carolina Girl!
    Pentair 1 1/2 Hp
    Guest
    Is that ok?
    What kind of acid? Muriatic acid or dry acid won't have any effect on chlorine levels. If you are talking about ascorbic acid used in stain removal it will deplete FC until it is completely oxidized but you need to bring the chlorine levels up very slowly or the stains can return.
    FC is the only kind of chlorine you want. CC is the 'bad' chlorine that you get rid of by shocking the pool. If your stabilizer is very high it is possible that you won't be able to hold a FC level because of nascent algae. I believe you said in a different thread that your stabilizer was 90 ppm which is too high. IF that is the case you need to work on lowering the stabilizer level in your water. If you would post a full set of test results and tell us exactly what you put into the pool we can help you. Without that information it's really impossible to know what is going on in your pool.
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Read the Ascorbic Treatment sticky to answer your question.
