Thread: Two problems I have
    Two problems I have
    1) I bought my house with the pool and chlorine tablets were already here and I don't know how old they are. The problem is that I have put many tablets in and tested the water but still not getting into the levels that are needed for safety. Is there a chance that the tablets are so old that they are basically useless and it really doing anything?
    2) with the pool just being opened for the summer. I notice that there are patches of dirt on the floor. When vacuuming the patches come up and then circulate into the water . I have vacuumed it a couple of times but once I stop vacuuming the dirt seems to settle again.
    Any suggestions on the above two problems?
    Above ground, oval pool
    12 x 18
    DE filter by heyward
    Casey's Avatar
    SW PA
    10,424
    Re: Two problems I have
    Sounds like you are in the midst of an algae bloom and you need to manually dose with liquid chlorine. How much? I don't know because you have not posted what your test results are. Tell us what your water looks like.
    Please read Pool School and invest in a reliable test kit as strips and pool store testing can be awfully conflicting. You can find the link to the TF-100 in my signature.
    Welcome to TFP!
    Jun 2012
    Howell, NJ
    977
    Yep, to answer your questions we will need valid (not pool store or strip) test results. Sounds like you will need to follow the shock process, which is linked to in my signature. Since your pool is constantly chlorinated using trichlor tabs, I bet your CYA is sky high, and you will require a partial drain and refill to lower it before you can easily follow the shock process.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
    I recommend grabbing a big glass/mug of something and settle in for a few hours' reading in Pool School. It'll be an eye-opener.
    If pucks are kept dry, they'll last for years. You'll be using them on vacations for years to come.
