Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Pool cooler
    Jan 2013
    Houston, TX
    1,079
    Pool cooler
    Even in the oppressive Houston humidity this had taken us from 92 degrees to 86 in a day. LOVING IT![attachment=1:g0txg4nm]ImageUploadedByTapatalk 21372011076.177248.jpg[/attachment:g0txg4nm]
    [attachment=0:g0txg4nm]ImageUploadedByTapatalk 21372011099.881342.jpg[/attachment:g0txg4nm]
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Pool cooler
    Nice!
    Love TFP? Become a
    TFP Supporter!
    Re: Pool cooler
    Is that a shower head? Way cool way to make a fountain!
    Summer Escapes 15'x42" AGP, Intex 14" sand filter, Intex SWG
    Jan 2013
    Houston, TX
    1,079
    Re: Pool cooler
    I looked at shower heads but wanted higher flow so I went with a watering wand and pulled the head from it.
    [attachment=2:1bn8rwm8]ImageUploadedByTapatalk 21372016674.912428.jpg[/attachment:1bn8rwm8]
    [attachment=1:1bn8rwm8]ImageUploadedByTapatalk 21372016701.678002.jpg[/attachment:1bn8rwm8]
    9 bucks at lowes.
    The big one cooled it off super fast on high. We are trying version 3 on low to see if it will maintain 85.
    [attachment=0:1bn8rwm8]ImageUploadedByTapatalk 21372016791.233118.jpg[/attachment:1bn8rwm8]
    The only glued connection is the one into the wall. The first 90 is secured with a set screw. The rest are friction fit until I find the final configuration.
    Jan 2013
    Houston, TX
    1,079
    Re: Pool cooler
    [attachment=0:3o91dkcx]ImageUploadedByTapatalk 21372016985.656780.jpg[/attachment:3o91dkcx]
    For comparison sake.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Pool cooler
    Karmabiker, run the pump at night and you will get more efficient cooling and less evaporation.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Jan 2013
    Houston, TX
    1,079
    Pool cooler
    Tip much appreciated ... but ...
    We tried running the pump last night and got minimal cooling compared to the usual overnight temp drop. I suspect it is related to the crazy high humidity at night in Houston. The temperature delta between the head and the surface impact point during the day is about 21 degrees (using a SCUBA computer) during the day.
    I honestly thought we were going to see a really big overnight drop and was crazy disappointed this morning.
    The first 2 prototypes were on a regular jet in the deep end and got decent height. V2.0 (first post) has 2 times the height and distance. It seems the evaporative cooling component is far more effective than the ambient cooling.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Pool cooler
    Amazing what a difference in humidy makes. Here in Tucson it has been over 100 for 28 straight days. This morning my pool was at 84 and the spa at 82 (shallow water). I have to run my solar system to WARM the water or my wife complains its too cold.
    chiefwej
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Pool cooler
    You get a 21 degree drop? Amazing! I get 10.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Pool cooler
    Quote Originally Posted by karmabiker
    High humidity should help with evaporation loss. I only get about 5-9*s running during the day. 15-19* running at night. Last year I got my temps down from the mid 90's to 80* before I was getting complaints on it being to COLD! Run time at night also determines temp also. 7-8 is were I am at peak summer.
    Jun 2013
    Southwest Arizona (Yuma)
    125
    Re: Pool cooler
    Karma,
    What size PVC did you use for that? 3/4"? Is there any special fitting you need to put on the end that plugs in to the discharge? I would like to do something like this as well. our pool gets up in the 90s regularly especially when it a 115 outside like today . I have an aerator but it doesn't put out too much of a spray. I'm in SW Arizona so running the pump at night is a must.
    Thanks
    My pool:
    Built 2004, 14K gal, IG plaster,Pentair WhisperFlo 2 HP pump(1 speed), Pentair FNS Plus DE filter,
    In Floor cleaning system, Attached Spa with Spillover seperate WhisperFlo pump for jets.
    Jan 2013
    Houston, TX
    1,079
    Re: Pool cooler
    Jt,
    It's 2 inch PVC. There is a threaded to 2 inch fitting that goes into the socket behind the eyeball. I'll try to get some good pictures tomorrow that explain the whole thing.
    Chris
    Jun 2013
    125
    Re: Pool cooler
    Thanks Chris!
    My pool:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Pool cooler
    Score another one for a simple, yet effective solution.
    Aug 2010
    New Caney, TX 77357
    184
    Re: Pool cooler
    I live NE of Houston in SE Montgomery County. My pool only gets a few hours of direct sun due to lots of tall trees on the south and east sides so the highest temps I see are around 78. The downside to that is that the pool warms up later in the spring and cools off earlier in the fall.
    Water temp Wed night at 9PM was 69 DegF. That's getting a bit on the chilly side (for this area).
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
    Jan 2013
    Houston, TX
    1,079
    Re: Pool cooler
    Correction on the size. It's 1.5".
    To install you remove the eyeball and the insert the eyeball screws onto. After that easy cheesy. Just get all of the angles correct before gluing based on how far the threaded part screws into the wall.
    Aug 2011
    Central Valley California
    121
    Re: Pool cooler
    That's a great idea. I'm going to have to try that. What about putting a by-pass and valve on it to turn it off should the weather change and you don't want to cool the water?
    23,000 gal IG Plaster 1989
    Purex Triton FNS Plus DE Filter Model FSNP 60
    1 Hp pump, Polaris 380 w/booster pump
    700 Gal Spa
    Laars Lite Heater T-F 100 Test Kit
    Jan 2013
    Houston, TX
    1,079
    Re: Pool cooler
    I just unscrew them and put the eyeball back in.
    Bypass would work well I'm sure.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pool cooler
    I've got one of the cheap ball valve/union combos on mine, I just turn the valve off when we're not using it.
  20. Back To Top    #20
    Jun 2013
    125
    Re: Pool cooler
    Very cool! I'm definately going to try this thanks for posting the pics.
    My pool:
